Old 06-28-2014, 01:39 PM   #1
Fan Bolts
Tom, I think it was you that had the fan go thru the radiator on your '08??
Are those the bolts that hold on part number 7 in the attached pic?
The pic is specific to my VIN so if those are the bolts that sheared off then I may have the same problem one day, since it appears I only have four bolts.
Boowho??
boowho is offline   Reply With Quote
Old 06-28-2014, 09:25 PM   #2
BTW.......
Also have now figured out that the "gearbox" associated with the cooling fan is for side mounted radiators ONLY.
We don't have that gearbox.
Boowho??
Old 06-29-2014, 04:44 PM   #3
tmmar's Avatar
Boo,
My fan did not go through the radiator. I contacted DOT and NY State dept. of Consumer Affairs. They contacted Daimler and were able to convince them to change the fan hub as a safety issue.
Good luck,
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-29-2014, 10:00 PM   #4
Originally Posted by tmmar View Post
Boo,
Good luck,
Tom
So what did FL do to fix your issue? It sure looks like I only have 4 bolts and I think somebody said the "new" one has 5.
Boowho??
Old 06-30-2014, 03:45 PM   #5
tmmar's Avatar
Boo,
They replaced the 4 bolt hub with a 5 bolt one. When I asked how they could do that they said the 5th hole was already there and they just bolted the new one on. They were able to crawl under neath and and I think they removed the air filter and were able to reach the area and replace the hub.
Tom
Tom and Margaret
fan
