Old 08-10-2015, 06:23 AM   #1
Fan hub bracket sheared bolts
Well it happened. As read about on this forum ( Radiator Fan Trouble ) and others before as some of you may be aware of the issues with the radiator fan hub bracket bolts failing. Mine failed yesterday, thankfully only 15 minutes from home returning from vacation. Big mess, overheated, fan blades contacted the shroud, destroyed belt (which I had just changed) etc etc. So my journey begins. Will be calling Freightliner this morning to complain. Why won't they just recall this!!!!
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
fan
