Originally Posted by BuckW
Went out to the coach today to turn on furnace to start packing to leave on Sunday. No power at the heater/a/c control. No display whatever. To make things worse. Tried fireplace. No power.
Things I have done: Disconnected from shore power. Turned on and off disconnect switch. Checked fuses in front compartment and breakers under the bed.
So far no power to vent fans, furnace/a/c control, fireplace.
Any thoughts??
OK, even though the thermostat is low voltage, and even though the furnace is 12V, I THINK the thermostat get's it's power from the AC/Heatpump unit(s) so yours is IMHO purely an AC issue. (As in..... fuses/battery and related circuitry is not in play)
The first place to look, again, is the 120V breaker panel. Don't just look at the breakers, cycle them. Specifically the two supply breakers (50A) on the far left. In my coach the fire place and the front AC (most likely source for thermostat power) are on the same leg of the 120V system.
After that..... start at the pedestal and verify there's 120V on both legs. Then you need to verify, with a multimeter, that the distribution/breaker panel is getting juice to the leg that the AC/Fireplace are on.
If you are not comfortable taking the cover off the breaker panel and poking a multi meter into "hot" locations......Get someone who can.
Don't know you model by heart, but there are most likely other users on that leg. In my case the washer/dryer. Is anything else not working?
