Old 05-19-2012, 07:19 AM   #1
klucas's Avatar
Fiberglas roof question.
I have a fiberglas roof on my berk. The dealer says there is no need to do any maintenance on it. Does anyone here put any type of wax like nufinish to protect from sun damage? I would assume if you need to wax the Fiberglas gel coated walls it may not hurt to do the same to roof? Thanks for any input. Ken
klucas is offline   Reply With Quote
Old 05-19-2012, 08:08 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
My Georgetown has the same roof. I usually get up there twice a year to wash off all of the dirt and debris and then check all of the caulk etc. I use Simple Green and a scrub brush. The roof has a little dimple effect to it and the brush works real well. Once I complete that I wash it with the same stuff I use on the sides Gel-Gloss. It's a cleaner / wax for Gel-coat. The roof is still nice and white and I don't see any signs of it degrading after almost 6 years.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 05-19-2012, 12:03 PM   #3
popbreed's Avatar
When I wax the exterior of my Lexi, I also wax the fiberglass roof. I use Nufinish on both.
popbreed is offline   Reply With Quote
Old 05-19-2012, 07:18 PM   #4
klucas's Avatar
Thank you for the info. I was hoping for no maintenance. Looks like I will be spending a few hours waxing the roof this weekend.
