Old 05-12-2015, 04:32 PM   #1
2014 360 QL
po 185's Avatar
fiberglass roof manitenace
I email randy to make sure that I have a fiberglass roof on my MH 2014 360 QL . and he said that I did and just clean it with soap and water and keep up with the calking around all the vents and outside edges. but he did not say what else to do !
so what else do I need to do to keep it up. mine has the worm pattern in it.
2014 360 ql
po 185 is offline   Reply With Quote
Old 05-12-2015, 06:47 PM   #2
nothing else really. I washed and waxed mine only to be picky.
James
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 05-13-2015, 10:56 AM   #3
Campin Cajun's Avatar
I've read that some people apply Mop & Glow or Zep to the roof to help stop the caulking that will occur over time that causes the white streaks down the sides of your Moho. I just wash it a few times a year. I never applied anything to it.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-16-2015, 01:23 AM   #4
Berkshire club
Berkshire Driver's Avatar
i just keep it cleaned so i can inspect it before and after each trip pretty much maintenance free compared to the old rubber roof pain in the ****
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 05-16-2015, 01:48 AM   #5
2015 Forester MBS 2401W
HomeOnWheels's Avatar
What type of caulking is good to use up there?
Jeff
HomeOnWheels is offline   Reply With Quote
Old 05-17-2015, 09:41 AM   #6
Berkshire club
I use Dicor self leveling lap sealant for use on horizontal RV roof surfaces, including rubber, TPO, metal, fiberglass, aluminum or wood. Seals along roof edges, around vent covers, vent pipes, air conditioners and screw heads. Remains flexible. UV-stabilized to prevent deterioration and discoloration. 10.3 oz. tube. item no 501lsw
fiberglass, roo, roof
