Old 01-06-2015, 01:40 AM   #11
edgewant's Avatar
I don't have a fireplace in my 2013 390RB but when trouble shooting an electrical problem that involved the refrigerator I ran across an odd switch box under the dinette slide. Turns out it is a cutout switch that removes power from the outlet in the space occupied by the fireplace. The slide has to be extended all the way in order that the outlet gets power. If you moved that slide since it worked you may want to check that switch. It has a button that is depressed until the slide is fully extended.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 01-06-2015, 08:39 AM   #12
Scokat's Avatar
pulled the dinette slide in and put it back out, fireplace started working. thanks
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
