I really don't think that is your problem, what they are talking about is overheating, overheating should not trip your breaker, I had the same problem with mine shutting off every ten mins. If it is going off on over heating, you have to go through the procedure to reset the board. That's shutting the switch off and turning the breaker off for 15 mins, then turn the breaker on and then the first place, I just went though that with mine and Coachmen sent me a new Fireplace. Still after it did that at least 5 times, it still never tripped my breaker..hope that helps, the reset board procedure is on the internet not in the manual,
Coachmen M/H
Concord
2018 / 300 DSC
