Old 08-22-2014, 01:52 PM   #11
Congrats on your new DP. We have had Gas, Propane and DHL motor homes and I feel the DP is by far the best choice. One the upside you get a much more substantial unit with more power, better braking, longer life, and much more.
On the down side they are much more.expensive to fix and maintain.
My first and best piece of advice for you is ... even if it is not a requirement in your region to get air brake certified .... do it anyways. In our area the 2 day course costs about 150 dollars but is well worth is. The majority of the course is on how air brakes work, how to identify problems and what to do if they occur.
Unlike hydraulic brakes ... Air brakes are an open system. This means that each time you thought the brakes you loose a small volume of air. If you are in the habit of pumping your brakes on the way down a hill, you can very quickly run out of air and find yourself with no brakes.
Air brake systems have and in line compressor that is constantly replenishing your supply .. However if is very easy to outset that supply.
On a general maintenance front I have been told by Cummins that you should never store a MH for an extended period with dirty oil ... As dirty oil is very acidic. I take my unit in for engine and genset service once a year just before putting it into storage.
Always let your unit come up to temp before driving it under load. This is easily determined through the Allison display.
Other than that ... not much different than gas
Enjoy
Tim
lefaivre is offline   Reply With Quote
Old 08-22-2014, 01:57 PM   #12
dan-nickie's Avatar
Good stuff.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-22-2014, 09:14 PM   #13
Grip it and Rip it Jim, you will be just fine! The computer has it all..
RodneyD is offline   Reply With Quote
Old 08-22-2014, 10:02 PM   #14
Iwannacamp's Avatar
IMHO. One cannot beat Schaeffers oil products. Fuel, oil and lubes.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 08-23-2014, 12:59 PM   #15
gasman94's Avatar
X3 on Camp Freightliner. First diesel here also.....no comparison, but as stated above, maintenance costs can be high. You can offset by doing some work yourself. eg. Oil changes $80 myself....$200 at shop. Have fun with your new coach!
Rich
gasman94 is offline   Reply With Quote
Old 08-23-2014, 05:28 PM   #16
CAT-RN's Avatar
Not sure from your post Jim as to what you purchased. But if you run into any issues a question on the forum will most likely get you a correct answer quicker than anywhere else.
Did you buy a coach from Total Value?
Russell
CAT-RN is online now   Reply With Quote
Old 08-23-2014, 11:12 PM   #17
Gas man
Things must be a lot cheaper in the US. In western Canada the oil alone costs 90 dollars and up ... not to mention the cost of the filter.
The cost at a shop would be more than twice as much as you quoted.
Old 08-23-2014, 11:53 PM   #18
gasman94's Avatar
Originally Posted by lefaivre View Post
Gas man
Walmart for Rotella and oil filter (I use Wix) at parts store. Freightliner oasis dealer in Kalamazoo, Mi $198 for oil change. I guess I'll quit complaining...LOL
Rich
Old 08-24-2014, 08:11 PM   #19
JimNix's Avatar
Originally Posted by f1100turbo View Post
So what are you buying?
TURBS
"SABRE OWNERS UNITED"
390-RB-60...
JimNix is offline   Reply With Quote
diesel
