Old 06-02-2015, 09:57 AM   #1
First the door awning, now this...
So yesterday I posted about my door awning not retracting. We bungeed it closed and while I was at work my brother drove the MH to the dealer. Well, he tried to drive it to the dealer. He got two blocks from the house and the check engine light came on and it lost all power. The engine starts up fine just no power to drive.
I had the MH towed to the Cummins service center here in town and I'm hoping it's something really simple but they can't even look at it until next week. We replaced the chassis batteries on Sunday so I don't know if that had anything to do with it. So, does anyone remember how long the Cummins warranty is and how long the Allison transmission warranty is if that's the problem?
Or any other ideas? Thanks again, what a week this is turning out to be.
2016 Forest River Georgetown 364TS
marcusfan is offline   Reply With Quote
Old 06-02-2015, 10:09 AM   #2
Flybob's Avatar
Do you have any warnings on dash display. Sounds like it is in low power safe mode due to sensing an issue. Could be lots of things, DEF etc. Check warnings. You may have to reset one after disconnecting power.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-02-2015, 10:55 AM   #3
I had that happen and it was something to do with DEF. they changed a part on top of the DEF tank. I could drive it but not much power.
Old 06-02-2015, 10:58 AM   #4
No warning other than check engine message.
Interesting about it possibly being DEF related. DEF was full but maybe could be bad sensor or something?
Old 06-02-2015, 06:54 PM   #5
My DEF was full and I saw I puddle under the tank. I looked it all over and couldn't find any reason for it to leak. As soon as I got on the road I knew something was wrong. I couldn't get it to 40-45 MPH. Luck I was close to a Cummins shop and they had me fixed and back on the road.
Old 06-02-2015, 07:51 PM   #6
dicky1243's Avatar
Thats is what they call the go home mode, with DEF you have to let it do a cleaning every once and awhile or you'll be on the side of the road. If the engine runs it sounds like what it takes a second time start to put the light to come on if you had an OBII you could shut the light at the same time it tells you what the code a P number. it could be caused but low fuel pressure or turbo-under boost ya know there a thousand code the 2 i gave are what i see most.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 06-02-2015, 07:52 PM   #7
Phil, my brother couldn't even get up to 20-25 mph. He didn't check DEF tank though because he didn't think about it because he hasn't driven a diesel post DEF. Frankly I didn't think about it either until you mentioned it and then I thought that makes perfect sense because if it was low on DEF, that's what it's supposed to do right? Go into low power mode? Sure wish Cummins could look at it this week.
I wonder if it is a DEF issue if that would be covered under the Cummins warranty? That would be a nice little surprise. Thanks for the input.
Marcusfan
Old 06-02-2015, 08:10 PM   #8
tmmar's Avatar
Marcusfan,
To answer your question, the warranty should be 3yrs/36000 miles.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-02-2015, 09:32 PM   #9
dan-nickie's Avatar
Originally Posted by tmmar View Post
Marcusfan,
I thought it was 5 on the engine/chassis and 3 on the allison.
Dang it wrong again.
Basic Warranty
Freightliner Custom Chassis Corporation (FCCC) offers the assurance of the industry’s most comprehensive warranty
coverage: a transferable, three-year, 50,000-mile limited warranty with towing and roadside assistance—and no
deductible whatsoever.1
You’re covered for two complete trips around the globe.
Description Time* Distance*
Basic Chassis (less drivetrain) 3 years 50,000 mi/80 500 km
Alliance Battery 1 year 100,000 mi/161 000 km
Brightwork 6 months Unlimited
Corrosion 6 months Unlimited
Crossmembers 5 years 100,000 mi/161 000 km
Diesel Emissions 2010† 5 years 50,000 mi/80 500 km
Drivetrain 3 years 50,000 mi/80 500 km
Frame Rails 5 years 100,000 mi/161 000 km
Chassis Paint 6 months Unlimited
Towing & Roadside Assistance‡ 3 years 50,000 mi
* Time or distance, whichever occurs first.
† Applies to vehicles equipped with EPA2010 compliant diesel engines.
Towing/Roadside Assistance fully reimbursed to the nearest Company-authorized repairing location. For a warrantable repair in a vehicle-down
situation, call 1-800-385-HELP.
Customer Protection Plans
FCCC Customer Protection Plans give you the option to extend your original factory chassis warranty above and
beyond the basic warranty of your vehicle.2 The Plan allows you to pick and choose the best package or packages
that suit your needs. And the best part of the Customer Protection Plan is that it’s the same factory warranty, backed
by FCCC, with no preauthorization or deductible required.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-02-2015, 09:55 PM   #10
Doesn't the Cummins have a DEF warning message or light that warning in advance of a shutdown that allows sufficient time to refill the fluid?
magpi26 is offline   Reply With Quote
awning, door
