Old 06-06-2014, 05:47 PM   #31
Maybe since it's rv related this wouldn't fly but what about contacting NHTSA. I can't think of anything more related to highway and safety and not just ours but all the other motorists on the road. Perhaps that would get FL moving? Just a thought.
Marcusfan
2016 Forest River Georgetown 364TS
marcusfan is offline   Reply With Quote
Old 06-06-2014, 09:25 PM   #32
Marcusfan
Someone pointed out that the NHTSA wouldn't get involved until a related fatality happened. However, there is an RV industry safety group that may be worth contacting. RV Safety & Education Foundation
Boowho??
boowho is offline   Reply With Quote
Old 06-07-2014, 07:43 AM   #33
Retired Trucker/43 years
Noneyerbusiness's Avatar
Did you try my advise? Contact Cummins Diesel directly?
Even if FL found something, they would refer it back to Cummins anyway for a solution.
As I mentioned before, I drove semi's for many, many years. Engine problems can be as simple as a loose wire connection.
Freightliner replaced 4 injectors in my truck, under warranty, when it was decided to replace the one they had just replaced several months prior I mentioned they were just throwing parts at a continuing problem. They ended up replacing the wiring harness on the engine .. problem solved, (But I did get several new injectors)
The worst thing that can happen for an owner, or the technician working on it is, 'I have an electrical problem, but it's NOT acting up now." I have spent hundreds of dollars chasing a light failure on a unit. I didn't like to, but the technician can't work for free.
All that said, your issues is not an aggravation, it could kill you and anyone else in the coach, and potentially take innocent other motorist's with it.
Why not take an additional moment and contact Cummins?
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 06-07-2014, 08:21 AM   #34
tmmar's Avatar
Originally Posted by boowho View Post
PM returned.
I have no problem with them not wanting to invest hours and hours chasing a (potentially) non-existent problem. However, a simple dump of the computer logs over the last 3-6 months would take maybe 5 minutes and could potentially save a life. You'd think they could do THAT much without a $160 (or so) charge.
And of course, those logs are completely "locked up" so i couldn't do it myself with a $25 tool from NAPA, right??
Bill
Bill,
I said the same to the tech at the Freightliner help line and he said that unless you get a check engine light, no codes would be set. Not sure why that is but that is what he told me.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-08-2014, 09:09 AM   #35
What Cummins engine do you have?
Here is a link to understanding them, (however, be fore warned even though you may identify a code #, there are sub numbers under that one, which only the computer link can know.)
Cummins Codes - Fault codes by engine model.
You may gain some insight at this link ...
Reading Fault Codes on Cummins ISB Engine - iRV2 Forums
2006 Ford F-150
Old 06-08-2014, 08:06 PM   #36
340HP . I'm told that unless there is a "check engine" light, then no codes can be read. I believe the ECM of which you're referring is back on/near the engine itself.
I've been talking about the dash board "magic box" up in front of the driver.
Have not called Cummins yet; waiting to find out what Tom comes up with.
But thanks for your insights as a hugely experienced user of this stuff.
Boowho??
Old 06-08-2014, 11:56 PM   #37
Ecopco's Avatar
I'd suggest sending a detailed certified return receipt letter to Freightliner. You then have essentially put them on notice. Their In house legal counsel should advise them to look into the issue and send you a response. Just my .02 cents
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 06-10-2014, 10:49 AM   #38
bud1249's Avatar
boowho
Have you heard anything from FL or anyone else on problem like I said before this has happen to me twice, it comes right back but still this to me is a problem
bud1249 is offline   Reply With Quote
Old 06-10-2014, 11:33 AM   #39
Berkshire 390QS
NO3putt's Avatar
Someone in IRV2 fourm just recently posted they had the same issue with their Cummins 380 engine.
Old 06-11-2014, 01:33 PM   #40
Thanks; may try that.
Boowho??
forest river
