Old 11-21-2014, 12:32 PM   #71
Yes we will be there. Texas wasn't working for us.
Old 11-21-2014, 01:04 PM   #72
I-RV's Avatar
Okay, let's get back to the engine problem! I know that intermittent problems are difficult. Here is a hypothetical FL encounter:
Say, you take the Berk to FL, hop in the Berk with a FL tech. for a test drive and the engine stops (LOL). Then back to FL shop and it doesn't fail again. What is FL's response then? Will they then try to investigate the problem?
My point is: is FL not believing people, or are they just hiding to save their warranty budget? If they are, they certainly are hurting their reputation!
I feel that even without undocumented evidence, from the shear numbers of complaints that they have had; a first class company would be doing some engineering studies on the problem to determine scenarios that could possible cause the problem.
Anyway; my 2-cents
Hank
I-RV is offline   Reply With Quote
Old 11-21-2014, 03:39 PM   #73
I know I posted this reply before but I had the same issue happen to my 2011 Berkshire last year and it ended up being the ignition switch. Might keep that in mind if they cannot find your problem
RNuzzolo is offline   Reply With Quote
forest river
