Old 02-04-2013, 10:43 PM   #1
ernest917's Avatar
Fluid level for slides
I know this is probably dumb but when do you check fluid level for slides - when slides are in or when slides are out??
ernest917 is offline   Reply With Quote
Old 02-04-2013, 10:47 PM   #2
TURBS's Avatar
In is the best option !
you don't want to check and fill when there open
TURBS
Old 02-04-2013, 11:00 PM   #3
2011 Berkshire 390BH
Superchief's Avatar
Ernest917,
Check while in (only need the front two in - the back two are electrically operated). Also make sure that the leveling jacks are retracted. All 4 leveling Jacks are Hydraulic. When the Berkshire Factory originally filled the Hydraulic Reservoirs, they only filled them half way. The Manufacture (Equalizer Systems) says that the Reservoir needs to be filled within an inch of the top.
Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 02-05-2013, 07:51 AM   #4
ernest917's Avatar
Thanks guys...
