Old 11-07-2015, 10:44 PM   #1
Fog light
Does anybody know where to get replacement fog lights for a 2011 Berk? One of our lenses is cracked.
Sent from my SCH-I535 using Tapatalk
Jeff and Elaine
2011 Berkshire 390QS
2 Lab Dogs-Eros and Star
1 Cockatiel-Lucky
dogsgocamping is offline   Reply With Quote
Old 11-08-2015, 01:15 PM   #2
fredhardy's Avatar
I spoke to my local dealer about replacing a broken lens and was told that FR parts will only sell the fog lights in pairs. So I replaced mine with LED fog lamps.
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
Old 11-08-2015, 01:52 PM   #3
Would you please share which ones you purchased? Part number etc.
Jeff and Elaine
1 Cockatiel-Lucky
Old 11-08-2015, 01:53 PM   #4
gasman94's Avatar
Had same issue and had them replaced at Goshen rally. There are some that might work on Amazon. Need to crawl under front to see wiring and attachment points.
Rich
gasman94 is offline   Reply With Quote
Old 11-08-2015, 02:55 PM   #5
BooBoo23's Avatar
Can you see the part # on the lens? It is usually embossed on the surface and hard to see but if you take a thin piece of paper and rub a pencil over it you can see it. It may be a fairly common lens that you may be able to find on Ebay or do a Google search for that part #.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is online now   Reply With Quote
Old 11-08-2015, 02:59 PM   #6
BooBoo23's Avatar
Can you see a part # on the lens? It is usually embossed in the plastic or glass around the top edge but sometimes hard to see but if you take a thin piece of paper and rub a pencil over it you can transfer the numbers and be able to look on Ebay or do a Google search for that number.
Old 11-08-2015, 04:34 PM   #7
I was thinking of going led. That would be an assembly I assume.
Jeff and Elaine
1 Cockatiel-Lucky
Old 11-09-2015, 06:44 PM   #8
BooBoo23's Avatar
If it is not a sealed unit you can probably find a LED replacement for the filament bulb. Is the lens removable? If so, Google for a LED replacement match.
Old 11-15-2015, 05:19 PM   #9
? Where is the switch for the fog light have a 2010 BH with the lights but have not found the switch.
outloud is offline   Reply With Quote
Old 11-15-2015, 05:42 PM   #10
Push on push off using the light switch. Must be on low beam to work
Jeff and Elaine
1 Cockatiel-Lucky
light
