10-31-2015, 07:35 PM
#21
7 Year Class A RV'er
LED's are definitely polarity sensitive and are extremely sensitive to good grounding. Get a couple of pieces of wire and touch the lights directly to a battery. If no light, reverse the wires. Still no light means bad lights. Someone mentioned a relay, which you should have had for the original lights. You shouldn't need the relay for the LED lights (less power required) but that relay may be keeping the LED lights from working. You'll need to bypass it and power the LED's directly.
2015 Legacy SR340 360RB
11-01-2015, 02:48 PM
#22
Fog light update:
I de-installed the lights and verified they worked directly on a battery. So a relay is not required. I also addressed the polarity question and the installed polarity/wiring was correct. I checked the power at the wires to the lights and nothing. So I'm in search of the fuse location. As noted previously, the fuse location is not noted in the owners manual so a call to the Forest River Tech Center will occur tomorrow.
Best regards,
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
11-01-2015, 02:52 PM
#23
Fred,
Happy to hear that you have narrowed the issue down! Hopefully FR will be able to help you tomorrow.
Tom and Margaret
2014 Berkshire 390bh-60
11-01-2015, 03:33 PM
#24
More than likely the power location under the hood. I believe the A class chassis is like the C class Fords with a fuse panel under the dash and a power panel under the hood. Driver side and there should be fuses and relays. Could be a bad relay or fuse. To check relay, Ford uses same in most locations. You can swap them to see. Chassis manual or on line can tell you what is where.
11-01-2015, 03:47 PM
#25
Dan
2014 Berkshire 390RB-60
11-01-2015, 03:50 PM
#26
Where is the hood?
Dan
#27
Nothing like the Ford! Freightliner chassis. Berkshires are a beast of their own!
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
11-01-2015, 05:06 PM
#28
Sorry about that. I guess there is nothing in the front other than inside under dash. Any compartments near the front with wiring? I guess they can, but I cant see wiring everything to the rear.
11-01-2015, 05:19 PM
#29
Fred, did you check to be sure high beams weren't on as suggested by some previous posters?
Rich
11-01-2015, 07:37 PM
#30
Who Dares, Wins
Originally Posted by fredhardy
Sorry for the "slow" response. I was at my 7 y/o grandsons football game this morning. I guess my priorities aren't the same as "Doc73"...........
No, our priority does seem to be the same, family first, as it should be. I apologize for being to quick to judge, I let words go to the keyboard that were better suited to keep to myself..
I know nothing of a Berkshire / freightliner so I will need to bow out of this conversation. I will offer one last thing to check or at least maybe was already thought about, did you test for power a bit in from the old ends of the wire? I say this in case water intrusion caused corrosion into the wiring a few mm or so and is not able to conduct power anymore. Otherwise I would guess a fuse shorted before a relay went but who knows, good luck. Electrical gremlins can be a bear sometimes.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
11-01-2015, 08:27 PM
#31
You are aware there are four fuse boxes in the compartment under DS. The fourth is located on the front panel up a little higher than the three facing the door.
2013 Berkshire 390BH
11-01-2015, 08:46 PM
#32
Hey "Campin Cajun" - I wasn't aware of that 4th fuse box! I pulled the cover just now and I'll look more closely tomorrow at early light! None of the fuse box diagrams in the owners manual looks at all like this box.
Thanks!
Fred
Fred Hardy
Phoenix, AZ
11-01-2015, 08:50 PM
#33
No problem Fred. I hope you find the fuse.
11-02-2015, 07:05 PM
#34
Fog Lights - question of the day
Also I have bought led Rv lights that the black wire is hot. White is ground.
Most regular lights are white or red is hot and black is ground.
11-05-2015, 04:07 PM
#35
Success! With Motodad's advisement, I went back out and checked my wiring and I had presumed that the white wire was my power source. I rewired the lights with the black wire hot (remembering the polarity of the fog lights) and they are now working! Thanks for all the inputs. I really appreciate the assistance!
Fred
Fred Hardy
Phoenix, AZ
11-05-2015, 04:09 PM
#36
Great Fred. Glad it was something simple.
11-05-2015, 04:16 PM
#37
X2!! Happy it worked out.
Tom and Margaret
11-05-2015, 04:25 PM
#38
x3. Nice call motodad!
Rich
