Old 08-09-2015, 01:41 PM   #1
JBoyer's Avatar
Forgive me - another TIRE thread
Hello forum friends,
I was taking a hard look at my Michelin 255/80r22.5 tires this morning, and the attached picture is what I discovered. The condition is similar on all four tires showing - assume the inner duals are the same. These cracks appear really bad (to me) but when I try to put the edge of a credit card in them, I can't. Regardless - the date code on all the tires is 1911 - or Mayish, 2011. I'm disappointed in the condition of these tires based on their age and miles, about 15k. Two questions - are these cracks what I keep seeing referred to as "zippering"? Second - my good friend/neighbor is a fleet roadside tire guy. He is telling me to look seriously at Toyo M154. I checked the specs on line and the tires are almost identical to the Michelins. Anyone running Toyo's? I see on some of the other coach web sites but was wondering specifically about Berk owners!
THANKS
Lurking - future Dynaquest XL owner
2015 Landmark Newport
2019 Ford F450 tow vehicle
sold 2008 Berkshire pusher
sold 2010 Mini Cooper Convertible toad
sold 2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 08-09-2015, 01:49 PM   #2
vinmaker's Avatar
OMG! Do not drive with those tires! You need to take those off and get them replaced ASAP. Those are bad stuff.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-09-2015, 01:57 PM   #3
Ford Idaho's Avatar
I take it that is a uncovered outside dual tire that has had more than it's share of sunshine treatment.
If so then that might be normal for todays tires.
If you like the looks and price of the Toyo's then go with them.
Drive it to the shop and pony up.
Old 08-09-2015, 04:13 PM   #4
Mine was the same and I was going to buy Mic.27580r22.5 but instead I did buy Toyo 265-7.5-22.5 so far so good inexpensive compared to the Michelin tires.
outloud is offline   Reply With Quote
Old 08-09-2015, 05:54 PM   #5
JBoyer's Avatar
Outloud - thanks. Have been PM'd by a few in other forums and so far, all good news. I have a Grand Canyon trip in a couple weeks and want new shoes before we pull out.
Thanks again!
Old 08-09-2015, 06:00 PM   #6
JBoyer's Avatar
Actually - not... I had the tires put on when I bought it. Since I've owned it, it's been parked in a three sided pole barn - the rear only getting about two hours of late afternoon sun. My next set will be covered - regardless.
Old 08-10-2015, 01:09 PM   #7
This is norm on old tires that sit in the sun and weather for the last 4 years. I had this happen and was given a break on the new tires. This is why many will put wheel covers on there tires to protect from the weather damage.
j free is offline   Reply With Quote
Old 08-10-2015, 03:05 PM   #8
Send a message via MSN to Tiggerdad
This is NOT normal for all tires. I subscribe to another forum and Michelin comes up often. Cracks like that appears to be normal for Michelin. Go to RV.Net and do a search for Michelins. You can subscribe free and there is a large number of members who can help with most any problem people have.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 08-10-2015, 03:16 PM   #9
Commercial Member
The cracks are NOT "Zipper" failures. Zipper is what can happen when a steel body tire is run significantly under-inflated. The Zipper failure occurs about mid sidewall.
RE the cracks you have. I have seen a few posts where people took their Michelin tires to a dealer and since the tires were under 5 years old Michelin gave them new tires at something like 70% discount. Not saying you will get this but if you are reasonable and don't demand a free set you might be surprised on the response from Michelin.
Tires should not have this level of cracking at 4 years service. Can you document the purchase date of the tires? That info might help.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA in Tuscon, AZ and Syracuse NY in 2020
Tireman9 is offline   Reply With Quote
Old 08-10-2015, 03:44 PM   #10
recall replaced my Michelis
Check the recall of Michelins. They just replaced 7 of my 6 mile a gal tires tat looked just like that with 11 mile a gal Uniroyals of same size for zip.
Jerry Leinsing is offline   Reply With Quote
Old 08-10-2015, 04:05 PM   #11
I have seen these cracks on Michelins, good years BF Goodrich and a few no name tires. This is a common problem and is the reason you should always check your RV tires.
Old 08-10-2015, 06:29 PM   #12
JBoyer's Avatar
Thanks for your insight - I'll check that forum. I've done a lot of reading these last days...
Old 08-10-2015, 06:31 PM   #13
JBoyer's Avatar
Tireman9 - thanks for the info. I'm doing lots of research but will not invest in Michelins again...
Old 08-10-2015, 06:36 PM   #14
JBoyer's Avatar
Jerry - I did have the tires looked at here in Albuquerque. It was an amazing learning experience. Immediately after one "tire guy" said they were good to go another wandered out and basically yelled for everyone to step back that the tires were going to explode any second...
These tires are not covered by a recall I can find. The Michelin rep did say they would pro-rate for a new set but I am not going to replace them with Michelins. I'm looking at other options - TOYO, B.F. Goodrich, Yokohama.
Was looking at an Over-The-Road trucking review of tires and tire construction, warranty, durability, etc, and I'm convinced there are many good, safe options at a better price point.
Old 08-10-2015, 07:03 PM   #15
I-RV's Avatar
JBoyer - You can do yourself a favor by going to 275/80 tires. I did and now only need 84 psi in the rear and 98 psi in the front, instead of the 110 psi that I had to do with the 255/80. If you change brands, you need to get into the tires weight ratings.
2012 Berkshire 390BH
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 08-10-2015, 08:17 PM   #16
Dutchtexan
Dutchtexan's Avatar
Whatever brand, make or size you get, no matter where you get them you can go to Discount Tire (discounttire.com) and get a warranty on them for about $35 per tire, great warranty that will cover anything and everything that can happen to your tires. They dont care where you purchased them you can still get the warranty. I have it on my car, truck, camper, boat and utility trailer tires. Bumped a curb once and blew out the tire, they replaced free no question asked.
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
Dutchtexan is offline   Reply With Quote
Old 08-10-2015, 09:24 PM   #17
kingwood390bh's Avatar
I had the Michelins and, at 5 years, had a front blow out. Interestingly, it was the inside of the tire, not where the cracks were. MIchelin warranted the blow out and I replaced all with Toyo 275s. Slightly wider but no change in mpg.
kingwood390bh is offline   Reply With Quote
Old 08-12-2015, 03:00 PM   #18
'11 390BH
Warranty would be nice, how do you make a claim when you're on the road and its all gone wrong? and what happens, the process must take longer?
I ditched Good Sam 6 years ago after they were not at all helpful in resolving a blown tire in the middle of nowhere in the middle of the night on a trailer.
kohersh is offline   Reply With Quote
Old 08-12-2015, 09:05 PM   #19
Dutchtexan
Dutchtexan's Avatar
Good question, i was referring to it thinking that you would change the bad tire with your spare and then stop by any Discount Tire Company and they will repair or replace it depending on if it repairable, otherwise they will replace it right then no questions asked. The really nice thing is it doesn't have to be damaged in the tread area, sidewall puncture no problem they will replace it. Unlike other places that will not.
Old 08-12-2015, 10:07 PM   #20
'11 390BH
The idea of carrying a spare around is not all that bad. I had a mounted 19.5 for my gasser that I decided was 1 million x more hassle than it was worth, bu having just a tire seems like s solid idea. Last time I had to replace one roadside it was a brand i never heard of, but I was glad to get it and happier to be back enroute
tire
