Old 07-23-2015, 05:53 PM   #1
DJP6371's Avatar
Found this under my bed????
Berkshire 390QS. Lifted the bed and this contraption was under it.
Does anyone know what it is?Click image for larger version
Name:	ImageUploadedByForest River Forums1437691961.793865.jpg
ID:	83906Click image for larger version
Name:	ImageUploadedByForest River Forums1437691984.563642.jpg
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 07-23-2015, 05:56 PM   #2
tnbendr's Avatar
Does anyone know what it is?Attachment 83906Attachment 83907
All I'm seeing is your slide motor and mechanism.
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 07-23-2015, 06:10 PM   #3
2011 Berkshire 390BH
Superchief's Avatar
As noted it is the Bed Slide Motor.....
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 07-23-2015, 06:17 PM   #4
ernest917's Avatar
FYI: better check the bolts under there.... They tend to loosen and allow the slide gears to slip down and you can't work the bed slide.... Trust me - I know !!!!
ernest917 is offline   Reply With Quote
Old 07-23-2015, 06:36 PM   #5
DJP6371's Avatar
So that's what it is! I thought it may have been an automatic bed lifter that I wasn't aware of.
Thanks my RV brothers!
Old 07-23-2015, 07:25 PM   #6
accumack's Avatar
I second tightening them or you'll hear the dreaded skip.
accumack is offline   Reply With Quote
Old 07-23-2015, 07:29 PM   #7
asquared's Avatar
Definitely check them, our slide actuator sheared its bolts off and had to be totally disassembled to get the slide back in. Not fun to do with no AC hooked up in NC summer heat/humidity. That was on our maiden trip last August.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-24-2015, 11:13 AM   #8
I've tightened mine at least 5 times, made several "mods" and the damn thing still slips. It's a POS mechanism, IMHO.
Boowho??
boowho is offline   Reply With Quote
Old 07-24-2015, 12:58 PM   #9
I believe that is the infamous Widget-Arm on the Maniform.
gthomp10 is offline   Reply With Quote
Old 07-24-2015, 03:12 PM   #10
B and B's Avatar
I would replace the nuts with Nylock then no more tightening required. There are different types of nuts, some with the nylon insert in the middle and. Ore common with Nylock on the end.
bed
