Old 10-11-2018, 02:11 PM   #1
mckyver's Avatar
Fresh water tank
When you fill the tank , once it gets full does it have a overflow ? or must i monitor the level with the meter ?
mckyver is offline   Reply With Quote
Old 10-11-2018, 02:30 PM   #2
Witch Doctor's Avatar
It should come out your overflow drain.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-11-2018, 02:35 PM   #3
cavie's Avatar
Overflow/vent line should be next to you drain line
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 10-11-2018, 02:37 PM   #4
mckyver's Avatar
thanks ,
Old 10-11-2018, 02:41 PM   #5
MillMitch's Avatar
It will come out the overflow, and may or may not stop. I saw a hint on a separate thread that seems to work. Turn your pump on, and when you see water coming out the overflow, turn a faucet on in the TT. On my last trip that didn't entirely stop the overflow, but by the time I drove several blocks to the site, it had stopped.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 10-11-2018, 02:45 PM   #6
mckyver's Avatar
thanks for the input.
Old 10-11-2018, 05:19 PM   #7
Check out a recent thread on this for Berkshires. You’ll see that the overflow tube loops higher than the fresh water tank in a lot of our coaches. That thread has a number of great examples folks have done to monitor and deal with that. If you do nothing the tank will eventually have enough pressure that it’ll push out the overflow, yes. Sometimes though, it’ll start a siphoning action and drain more than you bargained for and that thread has suggestions (such as above) to deal with it.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 10-11-2018, 07:21 PM   #8
Subsailor's Avatar
Igave hit the nail on the head for Berkshires. Although I know others were simply trying to assist, this is a case when incorrect information from those that do not own Berkshires can cause damage or at least a good headache.
Glenn and Darcy
2018 Berkshire 39A
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 10-15-2018, 05:33 PM   #9
Don't understand, what damage is going to done from a overflow, really there is nothing unique about a Berks overflow unless it's installed wrong. If the overflow is in the top of the tank, you can only cause a siphon until the water drops below the fitting, that is the same on almost all units. I sure would like to know that can happen.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-15-2018, 06:40 PM   #10
If your welding when assembled on the tank will consistently handle the pressure on it year after year then no issue. Go feel how thin they are and how they bulge when totally full and weigh those against each other.
fresh water, tank, water, water tank
