Old 09-20-2015, 02:52 PM   #1
gasman94's Avatar
Fresh water tank
Any idea why this hose to the right vents out to the street?
gasman94 is offline   Reply With Quote
Old 09-20-2015, 02:55 PM   #2
gasman94's Avatar
Pic
Old 09-20-2015, 02:57 PM   #3
tmmar's Avatar
Rich,
That is an over flow so when you are filling the fresh water tank, it will flow out that hose when full.
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-20-2015, 02:58 PM   #4
overflow
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-20-2015, 02:59 PM   #5
Just taking a wild guess and saying it's the overflow which releases air as you fill the tank...I'm presuming that is a fresh water tank...and when the tank is full or near full, water will come out. It's one way to tell if the tank is full. Just guessing as I'm not familiar with that set up.
I see I'm slow on the draw
Pipeman is offline   Reply With Quote
Old 09-20-2015, 03:58 PM   #6
gasman94's Avatar
Surprised that there is not a one way valve to keep dirt and such from backing into tank.
Rich
Old 09-20-2015, 04:31 PM   #7
CAT-RN's Avatar
It has to breathe when you use water to. A one way valve might stop it from allowing air in.
Also there have been issues with that hose siphoning water off when in a turn or stopping.
I drilled a couple more holes in the floor & raised that over flow tube higher. If it would run over while I filling the water just run out.
Russell
CAT-RN is offline   Reply With Quote
Old 09-20-2015, 04:55 PM   #8
gasman94's Avatar
Russell
Good point about one way valve, Russell. I think that I might do the same with my drain valve and drill some weep holes.
Rich
Old 09-20-2015, 05:08 PM   #9
CAT-RN's Avatar
I also cut a hole in the wall to the front of the water tank. I can open the basement door in front and watch the water tank fill.
Russell
Old 09-20-2015, 05:15 PM   #10
CAT-RN's Avatar
Fresh water tank
Here is a pic of the hole I cut into the front panel of the water bay. Click image for larger version
Name:	ImageUploadedByForest River Forums1442787312.695572.jpg
Old 09-20-2015, 07:02 PM   #11
gasman94's Avatar
Here is a pic of the hole I cut into the front panel of the water bay. Attachment 89388
Nice....
Rich
Old 09-21-2015, 11:07 AM   #12
I-RV's Avatar
Thank's Wayne for the PM. Gasman check out this prior post. I think it will answer all your questions - Hank
If You Want More Fresh Water
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
fresh water, tank, water, water tank
