Old 07-01-2015, 10:35 AM   #1
Fridge issue
I am reposting this in Berkshire page to see if anyone has any advice.
I have just about given up on the Dometic refrigerator we have in our 2011 Berkshire. We have had it for 3 years and we full time. The fridge is a 4 door sorry I don't have the model number. The fridge is also in a slide so we have two fans moving air across the coils. The fridge has never worked great but was ok. It seems like lately because we full time it is struggling to keep temps below 40. We have one fan inside the fridge and plan to add a second one. I also bought a dorm size fridge to keep all water and beer in that we keep outside.
All that said have I missed a quick fix?
We have decided that we must do something before we both die from food poison. Throwing away two beautiful steaks tonight was the last straw. so as I see it I can tear this out and put in a residential fridge but it would take a lot of wood work and adding a larger inverter. The cost goes up very fast doing all that. I also have talked to a few folks that have done the Amish mod on there existing fridge. As far as I can tell option 1 replacing the fridge would cost around 4000$.
Option 2 doing the Amish mod runs around 1700$. I'm looking for input into what is the best way and what if any other options are available?
Old 07-01-2015, 12:41 PM   #2
Berkshire 390QS
NO3putt's Avatar
Phil, since you full time and at one place a long time would consider a residental model as replacement. Might be less expensive also.
How are you and Dianna doing up in MI? we just got back from a 6 week trip up to MN and will be heading out 1st of Aug for 3 months. Cheryl has already told me when ours goes out we are replacing our with a residental model.
Skip
NO3putt is online now   Reply With Quote
Old 07-01-2015, 03:17 PM   #3
Berkshire 390QS
NO3putt's Avatar
Phil,
Can you find a residental one that is the same size as the one you have so you don't have to re do the cabinets. We found a samsung that is the same size as our dometic, just waiting for ours fail.
Old 07-01-2015, 03:24 PM   #4
The first thing I would do is replace the element. It might not be getting to the correct temperature. Does it work better on gas?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-01-2015, 04:30 PM   #5
I-RV's Avatar
Phil, I have a 2012 with the 12 cu ft Dometic. I, myself wouldn't put any money into the Dometic. I been studying the various post about retrofitting to a residential refrigerator and definitely will be considering it myself. Besides the inverter not being robust enough, you will find out that there is no inverter power for your Dometic. Therefore, a line needs to be run.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 07-01-2015, 05:15 PM   #6
tmmar's Avatar
If I remember from my '08, isn't there an outlet in the refrigerator compartment? It was on the left side up a little way. If the refrigerator runs on gas and electric, there needs to be an electric supply for the refrigerator.
Phil, you should take a look at yours and see if I am right.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 07-01-2015, 06:10 PM   #7
I works the same on gas or electric. It weird because it's not outside temperature sensitive. We will go a couple of weeks and it seems fine
Then it's up to 40 again. The freezer isn't staying cold. Ice cream is not possible. The problem is the fridge is in a slide. Anyone replace theirs that was in a slide?
Old 07-01-2015, 06:12 PM   #8
Tom there is a outlet that I always assumed was 110v but have not checked it. I'll put a meter on it
Old 07-01-2015, 06:13 PM   #9
Hank you are right I don't think that outlet runs off the inverter. I'll do some digging to see.
Old 07-02-2015, 08:00 AM   #10
Mmnsc's Avatar
Hi Phil
Hope you and Diana are doing well. The first year we had the MH with the Dometic refrig we had the same problem you described. When we went to Goshen that year we had the refrigerator incident the rep came to the camper while the refrig was out of the wall unit. He took the burner nozzle out and said tge "jewel" was bad and changed it. He also cleaned the heat chamber. Since then (and i don't want to jinx myself) the refrig has worked well the temp ranges between 33 and 38f which is acceptable. We have a guage inside plus i us tge infra red gun to check the inside stuff. If you can hold out maybe you should confront the Dometic guy at the rally and see what they can do. It would be cheaper and less aggravating than trying to get a residential unit in JMHO
Marty
Mmnsc is offline   Reply With Quote
fridge
