If you camp at temps below 40º you'll need the furnace the heat pump can't extract enough heat from the cold air. And the furnace on ours automatically switches on from heat pump at 32º I wish it were possible to reprogram the thermostat to do the switch over at 40º. We have electric space heaters for those temps to save propane when we are on full hookups.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
