Old 09-06-2015, 09:02 AM   #11
Erik Quentin or Eq. The dawg is 'cause 3 pekes rule the house. 87 was a life altering decision. I quit the liquid stupid!! Thanks for asking. I will try the backing of screws first. If that fails I will find a warranty shop closer than Elkhart, 250 miles from Peoria. The jacks are down tho. So manually doing I will have to do.
Eqdawg87 is offline   Reply With Quote
Old 09-06-2015, 09:48 AM   #12
Plugged in all night. Jacks wont rise, slides not moving...A new unit shouldn't need this already.
Old 09-06-2015, 12:27 PM   #13
I-RV's Avatar
Erik - I suggest that you call Randy at Lippert. the supplier of the hydraulics. Problem is that he will only be reachable this coming Tuesday. How high is the fluid level in the hydraulic tank? Check the fuse laying in among the hydraulic compartment wires. You may have to dig around to locate it. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-06-2015, 12:29 PM   #14
Originally Posted by Eqdawg87 View Post
@Paulie Boy, I can do that if necessary. The back 2 slides worked though? Might be they're not hydraulic. @I-RV, water was above plates, 4 batts 3/4th gallon. Don't think they even checked them when I bought unit. Is new 14 model on lot for a year, plugged in.
Sitting on the lot for a year without any battery maintenance could (possibly) have ruined the batteries. It did on my coach. Had to replace all four.
Only one was really "cooked" badly, but not replacing them all at the same time is just asking for the new one to fail very quickly. Just sayin'
Boowho??
boowho is offline   Reply With Quote
Old 09-06-2015, 12:50 PM   #15
I-RV's Avatar
Erik - Your back slide are electric and work off the batteries. Do they work. If not, you have battery problems like Boo cited may be the problem. Hank
Old 09-06-2015, 01:48 PM   #16
Yuppers, the back slides work great. I can hear the relays just click on the front two when the wife tried and I was outside. Going to pop the back open on the motor alittle and see if the brushes are frozen. Wish me luck.
Old 09-06-2015, 04:11 PM   #17
silver's Avatar
Is your parking break on? Jacks will not work if ti is off. Also slides will not work if ignition is on.
silver is offline   Reply With Quote
Old 09-06-2015, 05:03 PM   #18
yes, removed the back of brushes 1/8th inch and that did the trick...tho now I cannot tighten them back up, or it does same as before. So are the brushes bad? Since this is a new unit warranty void if I do much more than what I did I suspect. Any thoughts on that??
Old 09-06-2015, 05:59 PM   #19
Really strange.... If under warranty, I'd let them fix it.
I will say that if you have the same motor as me, the brushes are different than most I've seem. Most brushes press on the commutator in a direction perpendicular to the motor shaft. The commutator itself is aligned with the shaft, in other words and the commutator is cylindrical shape
The brushes on this motor press on a FLAT commutator (like a flat disk) that is (itself) perpendicular to the shaft.
May sound confusing, but the bottom line is that this motor is a LOT easier to work on if trying to replace the brushes. If you get all the wires disconnected you can then remove those two bolts and the whole motor come off in your hands. You will NOT lose any Hyd fluid as the motor and pump itself are two separate housings with regard to the fluid.
BTW, if they happen to replace your whole motor under warranty, try to talk them into giving you the old brush assembly. If usable, I'll pay you $40 for it. Hope I haven't broken a rule by making this offer.
Boowho??
Old 09-06-2015, 07:16 PM   #20
Yes, it's only 2 month on road. 1240 miles on it. 750 miles for warranty work from where I bought it, by the factory.
slide, slide out
