Old 11-28-2013, 12:44 AM   #1
Front TV Access 2008 Berk 360 QS
How the heck do you gain access to the front-mounted TV on a 2008 Berk 360 QS? Unlike the back (bedroom) TV, the 4 screws hidden under wooden dowel insets on the front don't seem to do a thing. Anyone tackled removal or modification?
John & Rosemary
2008 Berk 360QS
MBE 900-330 w/Allison 3000
Jeep Liberty Toad
JohnKen is offline   Reply With Quote
Old 11-28-2013, 06:36 AM   #2
NV245's Avatar
From front tv access in June, JBOYER replied
Speedmerchant,
Our original Westinghouse flat screen in our 2008 started giving up the ghost so we actually put a new tv in a couple weeks ago. So, I wish I could tell you the front tv is mounted the same way as the back, but that would be UNTRUE. Actually, the four screws through the wooden frame only hold the wooden frame. Having worked with a couple fellas from the assembly line, they walked me through the process. I'll try to be brief.
1. remove the screws from the plastic windshield curtain track till near the corners of the coach.
2. standing at the tv - looking forward and up, you'll notice 3 covered trim panels.
3. Remove the center trim panel by uncovering the button screws and pulling down. (NOTE: If you have the electric driver and passenger shades, those have to come down too so that the center panel can be removed)
4. Once the center panel is out, you will need sit on the dash and slide your arm in that small opening. That is all the room you are going to have.
5. The Westinghouse tv is attached with 8 M7 bolts. The top 4 are obvious - there are 4 more that are on the bottom, I could not see them, only by feel did I find them.
6. Once all 8 screws are out - the tv is free.
A couple hours - not hard, but tedious. I'm not a small guy...
The frame is incredible based on the size/weight of the tv. I mounted a new 39 inch Westinghouse and am loving it.
I have pics if you'd like. Send me a private message with an email and I'll send you what I have.
Good luck!
NV245 is offline   Reply With Quote
Old 11-29-2013, 03:19 PM   #3
oh yeah this was a ton of fun. And all I needed was to plug in an HDMI cable. I am a 6' guy and kneeling on the dash my arm barley reached the plug in and had to go by feel. I think those guys must have installed that tv before they put the windshield in....lol. Not an impossible job replacing or accessing but not the funnest.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 11-30-2013, 08:43 PM   #4
Thanks for the info. VERY helpful. Got the TV out today. Still recovering from the gymnastics needed. As an added bonus, I found a water leak I didn't know I had. It was caused by a poor seal on one of the overhead clearance lights. Waiting for things to dry out before putting things back together. I have some ideas on modifying the TV mount. I'll share the results when I get the job done.
John & Rosemary
2008 Berk 360QS
Jeep Liberty Toad
