Old 12-08-2013, 05:32 PM   #1
RKC02's Avatar
Frozen Lock
Hello All: Just checking in on this first:
I found the top lock (Trimark deadbolt) frozen today - the key would not even go into the lock. Sprayed in some de-icer fluid but that only allowed the key to go in part way. Planning on using a hair dryer to heat it up - hopefully that will solve the problem.
Has anyone else experienced this? If so, are there any other considerations to prevent possible damage?
Thanks in advance for any suggestions.
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 12-08-2013, 05:34 PM   #2
jtstromsburg's Avatar
Maybe heat the key first, and then maybe dip into RV antifreeze? Seems a hot key would work, but may refreeze in the lock...
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 12-08-2013, 05:51 PM   #3
rattleNsmoke's Avatar
Treat it like a car door lock. As the OP stated, heat the key and give it a try. The deicer spray should be used immediately afterward OR WD-40 to eliminate the water it will leave. Good Luck.
rattleNsmoke is offline   Reply With Quote
Old 12-10-2013, 04:58 PM   #4
2014 360 QL
po 185's Avatar
i have found out ,, if you use grafite on the key and lock before winter stets in it will keep the lock free and easy to use after you get the ice off of the outside of the lock
po 185 is offline   Reply With Quote
