Old 03-18-2016, 05:55 PM   #1
Retired IT Manager (NERD)
Fuel filter
Does any one know of a replacement filter for the FF63009 having a hard time finding one.
Neanderthal is offline   Reply With Quote
Old 03-18-2016, 06:38 PM   #2
15berkxl's Avatar
Big Dave have you tried CarQuest that's where I got my filters for other FL's.
How have you been have not heard from you in a while.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 03-18-2016, 07:04 PM   #3
Wayne doing ok. Fighting this cancer has taken it's toll. I will be so happy July 30th is my last day of chemo.
Old 03-18-2016, 07:56 PM   #4
15berkxl's Avatar
Dave did you try at Cummin's/cross point for the filter I see online it is there part number.
Wayne
Wayne
Old 03-18-2016, 10:26 PM   #5
Kenny kustom's Avatar
You could try Genos garage.
I buy bulk filter kits for my ram from them.
They should be able to cross the filter number.
Good luck!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-18-2016, 10:47 PM   #6
http://www.amazon.com/Fleetguard-FF6.../dp/B017BP54X4
2016 Sabre 36QBOK
Old 03-19-2016, 07:01 AM   #7
Thanks for the replies. No one is able to cross reference so ended up ordering from Amazon .
Old 03-19-2016, 09:35 AM   #8
15berkxl's Avatar
Good you found one. Since I have not services unit yet is this filter used on all of the Berkshires?
Wayne
Wayne
Old 03-19-2016, 09:41 AM   #9
klucas's Avatar
The one in the Amazon link above isn't for the berk. Go to a freightliner location and they have the correct ones in stock. The water separator is harder to find. I have only found them at the freightliner dealer. I also purchased a spare amber bowl on bottom of the separator as a spare.
klucas is offline   Reply With Quote
Old 03-19-2016, 09:43 AM   #10
I don't know if it is on all it replaced the FF6308 and FF6304. I called 7 truck shops and 4 parts store and no cross reference found.
Old 03-19-2016, 10:02 AM   #11
ID:	102320Here are the two filters on my coach.
Old 03-19-2016, 10:50 AM   #12
klucas's Avatar
I stand corrected. Mine uses a ff5632. They must have changed them recently. Same separator on mine the alliance.
Old 03-19-2016, 11:20 AM   #13
Genos doesn't list that filter, but they sell mostly fleet guard. Worth s call and ask?
2016 Sabre 36QBOK
Old 03-19-2016, 03:21 PM   #14
accumack's Avatar
A few years ago there was problem with some after market fuel filters for the Cummins engines and they started to deny warranty due to that and list exceptable fuel filters. I'll see if I can find that information again. I will only use Cummins accepted filters on my Berk.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 03-19-2016, 03:27 PM   #15
X2. No need to chance mistakes.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 03-19-2016, 03:37 PM   #16
Jim34RL's Avatar
This is a newly designed filter by Fleetguard that replaced the FF63008. The filter is now a NANONET element design for the B/L series engines used in non RAM truck applications. This filter should be available at a Cummins engine shop. The supersede filter FF63008 should work also, but it will be of a higher filtration rating.
I found this in the Fleetguard 2015 Filter and Chemical Cross Reference/ Product Guide with no other supplier listed.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
