Originally Posted by Oscarvan
AFAIK there's only two, and there was only two reported in Camp Freightliner. One is on the rail and installed by FL (the yellow filter/separator) and the other one is on the engine by Cummins. (The black one).
Waiting on the fuel line to ball valve fitting to arrive, then install the ball valve. THEN I can start the replacing of the filters.
My MH is in storage, so here are the photos and docs that I have.
My first picture is Fuel Filter FF630009 or 5304743.
The second picture is badly focussed unfortunately, but it shows the Fuel Filter noted above beside the yellow Fuel-Water separator with the drain valve below. There is a lot of paint on my Fuel-Water separator and I can't read the part number.
When I looked up the parts build list on my MH, I also found reference to:
1. Cummins 4934879 Fleetguard FS1065, which is a Primary Fuel Filter 10 micron water-separating Prefilter with WIF Sensor). I bought one of these and it doesn't have the plastic bowl below, but it has the connector and the drain. I think I'll explicitly try to buy the bowl and filter separately if I can find the number.
2. Cummins 4934845 Fleetguard FF5632, which is a Secondary Fuel Filter (2 micron). I can't find any information to cross reference it to the FF630009, so I can't be sure it is the same as what is on my MH.
3. RAI 025RAC10, which is an ISB02 inline Fuel Strainer on chassis. I can't find this on my chassis. It may be up near the fuel tank.
They sure don't make it easy to find everything in either the parts department or on the MH.
–Gordon
