Old 11-03-2014, 07:54 PM   #11
silver's Avatar
Originally Posted by silver View Post
you want to use Fuel Water Seperator Alliance ABP-N122 R50419. Do not discard the clear plastic bowl and do not use a substitute part.
I got the number off the filter as well as from Freightliner when I went to Camp FreightLiner
silver is offline   Reply With Quote
Old 11-03-2014, 09:26 PM   #12
Campin Cajun's Avatar
I knew you were right silver, it's the numbers ibrunning posted. Out of all the googling I did I only found 1 Alliance filter for sale on eBay.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-04-2014, 04:59 AM   #13
the numbers I posted were from the cross reference for fleet gaurd , napa and wix using the number from silver other post . I would not be afraid to use any of these as they are good respected filter brands . fyi wix makes napa filters and fleetgaurd is a subsidiary of cummins .
lbrunning is offline   Reply With Quote
Old 11-04-2014, 07:05 AM   #14
Iwannacamp's Avatar
Ok. 25 years in auto parts...21 at NAPA. Use the interchange as a guide...use the APPLICATION guide as the bible...and use the serial number/OEM information as the holy grail.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-04-2014, 07:41 AM   #15
TURBS's Avatar
Quick hijack.....
Managed my dad's napa for 10 years.
Turbs
Old 11-04-2014, 08:33 AM   #16
I wouldn't bother hunting down the same brand, even dealers interchange from what the factory puts on the vehicles. I have seen this many times, as long as they meet the cross reference specs you cannot get dinged on using a NAPA or WIX over a Alliance.
jbrostek is offline   Reply With Quote
Old 11-04-2014, 09:08 AM   #17
Iwannacamp I appreciate your experience behind the parts counter because i'm one of the people you deal with every day 25 + years working on trucks and heavy equipment and have plenty of experience finding parts. That being said sometimes the fuel water separator is not factory installed it is dealer installed i have replaced many alliance filters with ones from napa wix and fleetgaurd with no problems . imo the op needs to take the filter into a napa store or a truck shop so they can match it up but if it is the part number given by silver the numbers I gave are correct.
Old 11-04-2014, 09:22 AM   #18
EJM4's Avatar
The OP can substitute the filter. Alliance parts and filters are Freightliner's private label parts company. I have my coach serviced at Cummins and they interchange with Fleetguard.
The Fleetguard number that Cummins installed on mine is FS19521.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 11-04-2014, 11:21 AM   #19
silver's Avatar
you can buy Alliance ABP-N122 R50419 from Freightliner at the (1 800 ftl help) number. Also get a discount if member of FCOC
Old 11-04-2014, 02:57 PM   #20
NV245's Avatar
The FS1065 will not fit where the Alliance filter goes. Freightliner changed the separator when they installed the Cummins engine in their chassis. I tried, and the FS1065 I used could not be returned because it had become used by trying to install it. Also the fuel supply to this filter position is lower than the tank, so when changing this filter, fuel is constantly, slowly running out. The less time you have the filter off, the less fuel will drip out.
NV245 is offline   Reply With Quote
water
