Old 11-04-2014, 03:25 PM   #21
Iwannacamp's Avatar
from the Wix website... cross from ABP-N122 R50419
Part Number: WF10059
UPC Number: 765809226302
Principle Application: Freightliner Trucks - Complete spin-on w/ drain and sensor port (sensor size is 1/2-20 - plastic bowl no longer required) - OE version has open bottom that requires a reusable plastic bowl
Applications
Style: Spin-On Fuel/Water Separator Filter
Service: Fuel
Type: Full Flow
Media: Paper
Height: 8.125
Outer Diameter Top: 4.28
Outer Diameter Bottom: Closed:
Thread Size: 1-14
Beta Ratio: 2/75=3/9
Burst Pressure-PSI: 200
Nominal Micron Rating: 3
Gasket Diameters
Number O.D. I.D. Thk.
Attached 0 0 0
(O-Ring) Packed 0 0 0
Close Window
Old 11-04-2014, 03:27 PM   #22
Iwannacamp's Avatar
ohh and this part of it
Exact Match for Wix or Competitor Part Number - Search results for abpn122r50419
Click on a part number from the list below to see the part's detail:
Manufacturer Part Number Manufacturer Abbr. Wix Part Number Lead Time
ABPN122R50419 ALLIANCE AAC WF10059
For Reference Only. Check Vehicle Application Listing for correct WIX Filter.
No product in this catalog has been certified for Aviation use
Applications are verified for vehicles sold only in the United States of America.
Old 11-04-2014, 04:34 PM   #23
Campin Cajun's Avatar
Fuel/ water separator filter
I ordered the Alliance R50419, should be here tomorrow. Thanks for all the dizzying advice....lol.
I now hate filter shopping as much as plumbing shopping.
But on a good note, It will only cost me a total of $151 and change to change engine oil & filter, both fuel filters and oil and filter change on the genny.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-05-2014, 08:12 AM   #24
That actually sounds a little low to me. My old Monaco was about 150 in filters including the generator and 100 bucks in rotella 15w40 diesel oil (genset was a diesel as well.) I think part of that was due to the on engine filter having the water in fuel alarm, but even the oil filter for the ISC was 40-50 bucks.
jbrostek is offline   Reply With Quote
Old 11-05-2014, 11:20 AM   #25
I can put pics of the receipts, I bought all the oil at Walmart which saved a ton of money. Walmart Shell Rotella 15w-40 was $5 & change cheaper by the gallon than any other store in my area.
Old 11-05-2014, 12:00 PM   #26
Ahh, I figured it out, you have the ISB, not the ISC/ISL motor. 4 gallons covers all your oil needs for the 12 quarts for the motor and 3ish qt for the genset.
My old coach had the Cummins ISC and took 7 gallons per oil change (6.3 in the motor plus .7 for the filter) and another gallon to do the genset. So paying around 12.98 per gallon for it, I still spent 100 bucks in oil every year, plus another 125-150 in filters depending on if I got them locally or online (engine filter, 2 fuel filters, plus oil and fuel filter for the genset)
Now with the 5th wheel I just have about twice a year oil change needing 4 gallons and a filter on the truck.
Old 11-05-2014, 12:06 PM   #27
That's correct jb, I have the ISB 6.7L.
water
