Full Time or LLC will void Warranty
In the FR online manual for our 2018 Berk XL40B does not have a day use limit as you posted. Maybe they changed their mind, but I doubt it! This’s is all I could locate in the FR online manual, Honestly, FRs warranty is not all that great to begin with.
“NOTE:
Use your new recreational vehicle responsibly. Your camper was not designed to be used as a permanent dwelling, but for short-term and recreational use. If you intend to use your RV as permanent housing, it could cause premature wear on your appliances, furnace, water systems, carpet, drapes, upholstery, bedding and interior surfaces. This premature wear caused by permanent residency may be considered abnormal or abusive use and could reduce or in some cases void your warranty coverage.” 2018 FR RV, Class A Diesel MH
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
