Old 05-02-2019, 01:36 AM   #1
ernest917's Avatar
Furnace
Can’t get my furnace to fire off.... Have plenty of propane so that’s not the issue...
Is there a fuse I’m missing somewhere???
My control panel doesn’t show the “auto” “Low” or “High” options like I believe it always has....
ernest917 is offline   Reply With Quote
Old 05-02-2019, 02:58 AM   #2
Witch Doctor's Avatar
What control panel? Are you talking about a thermostat? Can you supply a little more information. I think your talking about a thermostat but really not sure.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 05-02-2019, 03:35 PM   #3
Try bleeding your propane line by turning on your stove burners and lighting them. Once lit, turn them off and try your furnace again.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 05-02-2019, 09:38 PM   #4
Dragonship Captain
Oscarvan's Avatar
If you are referring to the "auto" "low" and "hi" I have on my Dometic thermostat, they apply only to the rooftop units.
The furnace is pure 12V. When you say "fire off" I assume the fan is running and it's not lighting. Yes, verify propane with the stove then let it try a few times.
Then Google "sail switch RV furnace".
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 05-02-2019, 09:48 PM   #5
ernest917's Avatar
Whew...... I couldn’t remember... got down to lower 30’s in Flagstaff last night and furnace kicked on and kept things toasty.....
Old 05-02-2019, 11:19 PM   #6
Dragonship Captain
Oscarvan's Avatar
Glad you didn't turn ice cube on us.....
furnace
