Old 11-07-2014, 07:25 PM   #1
Furnace ducting question
Hello all,
I'm using my furnace for the first time and I have no airflow out of the vents at the bottom of the over-sized chair behind the front passenger seat. I checked the ducting under it and it appears to be connected. Anyone else have this? All other vents are blowing warm air.
Also, tried setting the thermostat (both zones) to "auto" and then had the furnace come on and before it cycled off, the zone 2 A/C came on. Supposed to be a 4 degree range but it appears that isn't working as advertized. Not wanting the units to fight all night I went back to "FURN" on zone 2 and "HP" on zone 1.
JJvike is offline   Reply With Quote
Old 11-07-2014, 07:32 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Can you trace it back. sounds like a pinched hose.
donanddona is offline   Reply With Quote
Old 11-07-2014, 07:59 PM   #3
Berkshire 390QS
NO3putt's Avatar
Just remember that the HP will freeze up if it gets around 40 degrees or so outside.
Old 11-07-2014, 08:46 PM   #4
Thanks! Did not know that. Hasn't come on once yet. The furnace is keeping it warm for now. Supposed to get to 41 tonight. I guess I'll turn off the HP.
Old 11-07-2014, 08:48 PM   #5
Going to try and trace the ducts behind the chair and maybe the cabinets if I get time. Thanks
Old 11-07-2014, 09:04 PM   #6
OK...........I'm a dumbazz. Please disregard this thread because I have, once again, proved my wife correct in her assessment of my level of knowledge.
There are two furnaces. Each with their own duct work. Never knew I had two of them. I am going to blame it on living in the south and really only caring about air conditioning. Thanks for those that responded and those that laughed without posting.
Have a nice night
Old 11-07-2014, 09:14 PM   #7
Cyclone
beipers's Avatar
Have a nice night
That was me, by the way!
I know a lot of people say the HP freezes up and does not work below 40. We've run ours for 2 years well below 40 w/o any problems. The unit will stop and compressor will cycle back to AC mode to keep the outside evaporator from freezing over. This is likely different depending where you are. The good thing about the fall / winter air in the midwest, it doesn't have a lot of moisture in it to condense out.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 11-09-2014, 07:44 AM   #8
JTN8's Avatar
X2!! I use my HP's all the time in temps that are freezing and sometimes below freezing and have never had an issue with freezing the HP's over.
Jason
2014 Berkshire 390BH
2011 cadillac SRX
Old 11-09-2014, 08:54 AM   #9
Witch Doctor's Avatar
That is only part true, As the temp drops the HP eff. drops also the norm is 35 degrees. The heat pump will forum ice on the condenser coils that's when it go's into defrost mode. Which is just the reversing valve reversing to A/C and shutting down the condenser fan motor so it will build heat and defrost. It never freezes up. The coil can be checked by the unit either with a sensor attached or a timer that puts it in defrost every 45 mins if needed.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-10-2014, 09:56 AM   #10
Gottawonder's Avatar
As an aside, there have been other threads in the Berkshire forum about heating systems acting wonky when the clock on the thermostat is not set.
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
furnace
