Old 01-05-2016, 08:41 PM   #1
Scokat's Avatar
furnace power
i have powe to the control panel however the furnaces stopped working. they were both working fine. tank says 1/2 panel says 2/3. any ideas.
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
Old 01-05-2016, 08:52 PM   #2
Scokat's Avatar
its running just not blowing warm air
Old 01-05-2016, 08:54 PM   #3
have you tried closing the tank valves tightly, then opening SLOWLY? its possible the excess flow poppet int he tank valve has tripped and shut off the propane (unless you still have propane at other appliances)
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 01-05-2016, 08:57 PM   #4
Blackhat6mike's Avatar
You may have the fan set to low or high and not "AUTO". the fan will run whether or not the furnace is fired or not. If on "AUTO", it will only run when fired and for a short cool-down time when the set temp is reached. Worth checking. One DAV to another.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-05-2016, 09:04 PM   #5
the furnace fan would not run though, only the a/c fan is controlled by the fan function on the thermostat. furnace fan is controlled solely by the furnace control board and kicks in when their is a call for heat (and should shut off after the furnace fails to light after several attempts)
'14 XLR 395AMP
Old 01-05-2016, 09:15 PM   #6
Scokat's Avatar
ok i started the stove it lit for 5 secs then went out. checked tank it says half way in-between 1/4 and 1/2. so i just installed the extend a stay and hooked up the new 100 lb propane tank and it works. i guess the coach tank gauge is wrong.
gotta love working on the coach at 10 pm at night when its 40 degrees out.
Old 01-05-2016, 09:23 PM   #7
yup, gotta love it! LOL
I never trust ANY gauge until i know how well they are calibrated. At least you know now that if its below half shes time to refill!
My 150gal fresh water goes from full to 2/3 within 20gal of usage, sits on 2/3 FOREVER and once it hits 1/3 ive only got 5-10gal before the pump sucks air (it doesnt even hit empty )
'14 XLR 395AMP
Old 01-11-2016, 12:24 AM   #8
sirozz's Avatar
Had the same problem in very cold condition. Tank gauge showed 3/4 inside and 1/2 on the actual tank. Both were wrong and simply adding propane corrected the issue. This only happens in freezing conditions for us
2016 Georgetown 350XL
sirozz is offline   Reply With Quote
Old 01-11-2016, 07:12 AM   #9
accumack's Avatar
We had the same problem back when we first got the coach and were stationary for 5 months. The level indicator in the propane tank stuck said we had 1/2 tank we ran out at 2 o'clock in the morning and 25 outside. That is when I got the extend a stay. and electric heaters. When I drove it to get the propane filled it then showed the correct level. I carry a rubber mallet now and tap the tank and that seems to work.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
furnace, power
