Old 05-30-2013, 04:05 PM   #1
Himcules's Avatar
fuse for lamp above the dinette?
for the life of me, i cannot find this fuse... i took off the glass shade and the bulb is fine. i looked in the 12volt fuse panel on the front and nothing labeled looked appropriate. i check all the lower amp fuses and none were blown.
any other places i can look?
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-30-2013, 04:12 PM   #2
klucas's Avatar
I had similar problem. And turned out it was the bulb. The bulb didn't look blown but it was. I changed it to a lower watt bulb so it doesn't get so hot.
klucas is offline   Reply With Quote
Old 05-30-2013, 04:15 PM   #3
Himcules's Avatar
thanks! good idea... i didn't have my multimeter handy when i was searching that one day... i'll test the socket next time... i should have grabbed another known good bulb and tried it inthere as well...
if it is the bulb, i might as well change to an LED bulb...
