Old 08-15-2015, 06:17 AM   #1
tnbendr's Avatar
Gas backsplash on jeep wrangler
For those of you with jeep toads, do you have a problem letting the gas nozzle shut itself down while filling and get a nice amount of backsplash from the tank? The nozzle does not fit all the way into the filler tube no matter how I turn it (I didn't try upside down yet). It makes a mess of the side of the Jeep and the ground.
Any thoughts?
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 08-15-2015, 06:32 AM   #2
crunchman12001's Avatar
Google it. Many complaints out there.
2015 F-250 FX4
Old 08-15-2015, 07:05 AM   #3
tnbendr's Avatar
Thanks Crunch, looks like the GM hose fix is the way to go and until I get that installed I'll just watch the gauge and be careful when filling.
Ben & Michelle
2015 Berkshire 38A
Old 08-15-2015, 08:36 AM   #4
Campin Cajun's Avatar
There's not really a recall on this but if you contact a dealer the parts for the fix are free.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-15-2015, 10:49 AM   #5
I have a 2014 Wrangler and haven't heard of the issue. I do not have a issue filling but when the pump shuts off that's it. No topping the tank. I tried it once and wore gas the rest of the day.
Old 08-15-2015, 12:20 PM   #6
tnbendr's Avatar
No, I let the pump shut itself off, I did not try to "top" it off. And it is very well documented, maybe on your 2014 it is already fixed from factory.
Ben & Michelle
2015 Berkshire 38A
Old 08-15-2015, 12:27 PM   #7
accumack's Avatar
I haven't had this problem either. I have a 2012 Jeep Wrangler.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 08-15-2015, 12:32 PM   #8
tnbendr's Avatar
I Googled it like crunchman suggested and it has been an issue that even Chrysler replaced some tanks starting with 2007 but refused to handle 2015 and 2006 for some reason they fabricated according to blogs
Ben & Michelle
2015 Berkshire 38A
Old 08-15-2015, 12:35 PM   #9
7 Year Class A RV'er
I also have a 2014 with no issues. I thought the designs were unchanged but not sure.
2015 Legacy SR340 360RB
Old 08-15-2015, 12:41 PM   #10
tnbendr's Avatar
I hope this link works;
2005-2006 TJ LJ - Fix for gas overflow issue - Jeep Wrangler Forum
Ben & Michelle
2015 Berkshire 38A
Old 08-15-2015, 02:04 PM   #11
baldeagle's Avatar
Send a message via Skype™ to baldeagle
I have a 2014 Unlimited...never experienced this problem. I have to assume that it afflicted older models!
baldeagle is offline   Reply With Quote
gas
