Old 07-24-2015, 10:33 PM   #11
Tom48's Avatar
My question, does that GenTuri make an appreciable difference in the noise around the camp or does it just served take the fumes up higher
Tom48 is offline   Reply With Quote
Old 07-24-2015, 10:58 PM   #12
jmgllt's Avatar
It helps gets the fumes out, when sitting under awning don't have to worry about CO from generator.
jmgllt is offline   Reply With Quote
Old 07-25-2015, 11:23 PM   #13
baddmann's Avatar
The design helps vent the fumes up so you and fellow camper/tailgaters aren't breathing them. The Gen-turi ad says it helps with noise, but you can still hear it running.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 07-28-2015, 04:47 PM   #14
captnrick3's Avatar
Originally Posted by KennyGolub View Post
Thanks for the reply.
I want to use the chrome exhaust extension for running the gen while on the road.
What is the diameter of the extension you purchased ? I'll make a trip to home depot on the way home from work today.
I'm thinking of using those small dent puller suction cups on the side for the strap. I ordered four in case I want to put two closer to the top.
Thanks again !
Ken
We use our Gen turi frequently on our Legacy. I bought the Gen turi suction cups rather than drilling into the side of the coach. They work great. I too just leave the adapter on the exhaust all the time, has not been a problem. Suction cups are from Camco so they are available easily. Here is where I got mine:
Gen-Turi Suction Cup Mount 2/PK - RV Wholesalers Parts Store
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 07-28-2015, 08:34 PM   #15
15berkxl's Avatar
We as well use the adapter while driving. You do not need the chrome adapter while driving down the road.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 07-29-2015, 06:13 AM   #16
Fulltime in our Berkshire
KennyGolub's Avatar
Thanks for all the replies.
I am going to set it up for the first time this weekend. I have yet to get the extension as Home Depot did not have any thin walled PVC. I'll try Lowe's.
I'll see if I like "the look" without the chrome extension. It's good to know it will run fine going down the road without it.
Thanks again to all.
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 07-29-2015, 06:24 AM   #17
KennyGolub's Avatar
Originally Posted by baddmann View Post
3" PVC thin wall sewer pipe with the flare on one end. I think I cut 2 ft or so and painted it grey. It slips on top on the Gen-turi and extends it above the roof.
Also, the adapter is an extension also. Once I installed it, there is is no need to swap it out with chrome extension. I have used my generator for over a year with no issues.
I also use suction cups, but I couldn't get them to stay on the side of the coach, so I made a bracket and used 2 suction cups that stick on the window. I'll look for pics and post if I can find them.
Could you tell me if you purchased the PVC at a local hardware store or something like home depot? I not having much luck finding it.
Thanks,
Ken
Ken & Laurie
2016 Chevy Colorado
Old 07-29-2015, 06:36 AM   #18
baddmann's Avatar
Yes, I bought it at Home Depot. Its actually called 3" sewer pipe with belled end. Its thin walled PVC pipe for low pressure sewer line.
Brian and Kelly
Old 07-29-2015, 06:59 AM   #19
15berkxl's Avatar
Gen-turi on the Berk
I guess putting an extension on the 3 inch pipe is a user preference I have used the standard setup from the manufacturer on 3 different MH and never felt or required the need to extend it.
Wayne
Wayne
Old 07-29-2015, 07:02 AM   #20
KennyGolub's Avatar
Thanks, baddmann....... I'm having more luck search for it as sewer pipe.
Ken & Laurie
2016 Chevy Colorado
