Old 06-27-2019, 07:30 AM   #1
General questions
I知 considering upgrading from a class c to class a. I知 looking at a 2014 forest river Berkshire 390 bh. Anything I need to specially look for before I buy? Also what are the routine maintenance areas for a class a diesel? Thank you for input.
Bob
Woundtight-48 is offline   Reply With Quote
Old 06-27-2019, 09:37 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. If you are not familiar with diesel driveline I would recommend having a diesel mech check things out before you buy. Good luck
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-27-2019, 10:06 AM   #3
There is a learning/comfort curve when changing rv types-at least there was for me. Having it checked out is good advice. Having either the previous owner or someone very familiar with the systems on the coach thoroughly go over them with you will help take any mystery (and make any troubleshooting much easier) out of the process. You’ll like traveling in your coach, we sure do.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 06-27-2019, 10:18 AM   #4
PPST Wannabe
kenandterry's Avatar
Bob
Deep pockets!!!!!!!
Everything maintenance related is more expensive than gas.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 06-27-2019, 08:30 PM   #5
Eagle5's Avatar
Is there any other RV besides a diesel?
2019 34QS with no ladder!
Eagle5 is offline   Reply With Quote
Old 06-27-2019, 09:56 PM   #6
Berkshire 390QS
NO3putt's Avatar
Some Berkshires had to have the front end upgraded due to weight. Check the sticker above the drivers seat in the cabinet for max weight and have it checked for weight. 2014 is about the right year for this issue. Also call freightliner and Cummins with the vin number and check to make sure all the recalls have been done and get history from them.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 06-28-2019, 04:44 AM   #7
+1
When i found my 2012 390BH ,I was very lucky to find a fellow forum member who traded it in. He was kind enough to spend about an hour with me on the phone going over everything. I was also able to call Freightliner and they sent me all the service records for the coach.
I bring mine in every year to freightliner for its oil change and lube, and pick about 50-70 % of the stuff on the maintenance list to have them do. Usually around $1500- $2500 per year.
My front airbags were upgraded for more weight- but they also change all 6 tires!
Best of luck
2012 390BH
dave-g is offline   Reply With Quote
Old 07-05-2019, 11:45 PM   #8
omahagirl's Avatar
Our is a 2011 390RB 360hp. Hadn稚 had the update for weight but we had it weighed last year, a year after we bought it. The diesel division took great care of us and we even had a bit of fun in Elkhart. VA to IN to NH. A bit of a detour
omahagirl is offline   Reply With Quote
Old 07-09-2019, 12:38 PM   #9
mikeborny's Avatar
I would check to see if they have maintenance records for all work done in the past. Also, you may be looking at new tires for that year coach.
mikeborny is offline   Reply With Quote
