Originally Posted by mckyver
"No PCS module comm" , is showing on the monitor screen when the generator is turned on , any ideas if what is wrong and how I can fix ? Attachment 218713
Check fuse H01 on the PrecPlex panel under the bed base. Fuse H01 supplies +12V to the PCS, & the rooftop AC modules.
Are you sure it's only displayed when the Generator is on? That message, while on the Power Screen, has more to do with the PCS, than the generator.
The message "No PCS Module Comm" is a generic way to say your PCS (Power Control System) isn't communicating with the rest of the PrecPlex network.
FYI, the PCS is a device inside the 120V Breaker box that monitors 120V power flow, controls the Roof AC unit functions & manages Energy Management System for shedding of high amperage 120V components for better shore/generator system operation.
If fuse H01 is good, save yourself a ton of time & headaches from misinformation. Call Danny or Nick @ Precision Circuits.
Here is their contact info:
Phone:
(630)-515-9100 EXT:704
Email:
tech@precisioncircuitsinc.com
https://precisioncircuitsinc.com/contact-us/
