12-18-2017, 05:39 PM
Generator Antifreeze
Anyone put antifreeze into their generator to keep it from freezing?? If so, how much???
12-18-2017, 05:45 PM
Berkshire 390QS
What kind of generator, your manual should have recommendations. I think it is the same used for engine. Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
12-18-2017, 07:11 PM
Just as confused as you
If your generator has a radiator then it should have antifreeze in it already. Most generators I've seen on RV's are air cooled and don't need AF. Just the largest kilowatt generators will have a radiator and they are most likely too large to be on a RV.
Richard & Jill
12-18-2017, 07:41 PM
Dragonship Captain
The Berks (this is a Berk forum) have the Onan QD's which are liquid cooled. There was anti freeze in it from the factory. If it's more than a few years old a test strip to check on it is in order. If it's more than 5 years old a refresh wouldn't hurt. There's an expansion tank where you should be checking the level on a regular basis. When in doubt, consult the manual. The following video is very informative:
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
12-18-2017, 08:13 PM
Sorry, I just found this in Recent Discussions. And OP didn't state how old it is, I said if it has a radiator then.....
How many kw is that thing?
Richard & Jill
12-18-2017, 08:16 PM
Dragonship Captain
It varies. The smaller units are 6KW, the larger buses can have as much as 10KW
12-18-2017, 08:22 PM
I'll bow out now as it seems that a lot of Class A owners don't think those with lesser types of RV's should have an opinion even though many of the same componets are used in all types of RV's. Though having hydraulic experience, I have helped some in the CG who had problems with their levelers.
Richard & Jill
12-18-2017, 10:04 PM
Dragonship Captain
Nah, you're putting words in my mouth. It's not a matter of lesser. I've had TT's, Fiver, truck camper, it's all good. And on GENERAL fora I'll happily converse with everyone.
The point is that this is a Berkshire forum where Berkshire owners can come to efficiently communicate about THEIR units.
It would be the same as me going to the Fiver forum and interjecting how it works on my Bus when someone asks fellow Fiver owners about their unit.
It clutters up the forum, and adds to the already plentiful confusion. I've seen threads full of non pertinent answers to specific questions.
This is what general fora are for.
Nothing to do with the elitism you infer.
12-18-2017, 10:07 PM
Easy guy...... As the OP, I don't really care what the rig happens to be - if it's got a generator in it then I'm interested...
12-18-2017, 10:10 PM
I have a 08 Berkshire with a 7,500 W gen.... I'll dig out my manual and see what it says..... Thought this post might be faster but now not so sure....
12-18-2017, 10:41 PM
I have a Cedar Creek Champagne with an Onan 5,500 got me thinking. I need to check mine and see. I suspect it is air cooled.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
12-18-2017, 10:47 PM
Mine is definitely liquid cooled..... I don't have an Onan tho..... I'll have to go out tomorrow and ck the spelling of what I do have..,. A Gen something or other.....
12-19-2017, 08:12 AM
I have the same unit and same year. It is a Generic 7500 in a tan enclose. The antifreeze is green so I assumed it was Preston 50/50 mix. After ten years I would change it. I had to disconnect the lower hose to drain mine. I was able to get to it from the lower hatch, not the oil change hatch. I have been flushing mine every four years as Generic is out of the RV business I worry about getting major repairs such as a rotted radiator.
12-19-2017, 09:07 AM
I don't ow a Berkshire and I didn't stay in a Holiday Inn last night but one word of advise. Make sure you use the correct brand of antifreeze and don't put a silicate type antifreeze if it does not call for it. Also correct mixture is important.
2015 Flagstaff 831RBLSS
2015 Ram 2500 6.7 Cummings Crew
2014 Lowe Stinger 175
2013 FJR1300
12-19-2017, 02:57 PM
Just went out and checked my coolant and I'm good to -40 degrees.... Whew.... One less thing to be concerned about....
12-21-2017, 05:50 AM
Checking the temperature rating is important, but the antifreeze should be changed every 5 years. Like Cummings says for the coach motor.
2012 390BH
