Old 06-10-2016, 11:53 PM   #11
Bluepill's Avatar
You need to check the voltage at the generator starter terminal while you are trying to start the genny. If it's above 9.6 volts, look for a bad starter or internal connection. If its lower, check supply connections and batteries.
Good video here:
https://youtu.be/z-X6L3St5Vw
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 06-17-2016, 09:58 PM   #12
ernest917's Avatar
SUCCESS !!!! I now have a $800 starter in my generator and it fires right up!!!!
ernest917 is online now   Reply With Quote
Old 06-17-2016, 10:00 PM   #13
ernest917's Avatar
Actually a $874.00 starter... $250.00 for the part and bend over for the rest.....
battery, generator
