Old 05-05-2015, 08:21 PM   #11
The air coupler in your genset compartment is used primarily for towing. If you ever need to be towed the driver will hook his air line to your coupler so your air brakes will have the proper air pressure to keep them from locking up. It is also a handy air source for topping off your tires, bicycles, rafts etc.
RodneyD is offline   Reply With Quote
Old 05-06-2015, 06:37 AM   #12
15berkxl's Avatar
Wow now that you mentioned it that makes sense. I always thought it was for airing up none nitrogen filled tires. Never considered towing aspect thanks for the enlightenment.
Wayne
15berkxl is offline   Reply With Quote
Old 05-06-2015, 07:43 AM   #13
I-RV's Avatar
Originally Posted by iowasparrow View Post
Don't use it to fill your tires. The air that comes out of it is not compatible with the nitrogen you put in your tires. I think it's a different kind of nitrogen.
The primary use of nitrogen in tires is because it is a large molecule and does not seep through the somewhat porous rubber tires. Plain old air is 78% nitrogen. Check out the differences between air filled tires versus nitrogen filled......
Should You Fill Your Car's Tires With Nitrogen?
If you spent a lot of money filling your tires with nitrogen, then do not use the MH's air coupling. Otherwise, the air coupling can be used for topping off your MH's tires.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 05-06-2015, 08:42 AM   #14
edgewant's Avatar
Since the oxygen molecules in air are "smaller" then over time as the oxygen seeps out and you refill your tires with air to bring them to proper pressure you would tangentially approach having just nitrogen in your tires.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-06-2015, 08:51 AM   #15
edgewant's Avatar
As you can tell I don't buy into the Nitrogen hype!
edgewant
Old 05-06-2015, 01:13 PM   #16
silver's Avatar
If you ever have to be towed you have to tap into the air system at the air dryer. I know as I have been there. The air source by the generator will not work. Only for airing tires and other user air needs.
silver is offline   Reply With Quote
Old 05-06-2015, 01:28 PM   #17
TURBS's Avatar
Oh and whys that?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-06-2015, 02:47 PM   #18
We have a 2015 38Rb. Does anyone know what size air coupler that is in the front generator compartment. I'm going to get a 50' hose this weekend.
Thanks in advance!
2015 Berkshire 38RB
2014 Honda CR-V toad
bstnet is offline   Reply With Quote
Old 05-06-2015, 02:49 PM   #19
TURBS's Avatar
There's several "sizes or should I say styles of couplers.
I'd take your coupler off to be sure you get the right one.
TURBS
Old 05-06-2015, 02:51 PM   #20
TURBS's Avatar
TURBS
generator
