Old 05-04-2015, 03:43 PM   #1
Generator compartment.
I was having the tires on the Berk filled with nitrogen this weekend and being a type A, I was poking around the generator cavity. I noticed what appears to be a quick connect for an airline on the firewall. I've looked through all the manuals and can't find anything. Any ideas?
Paulie Boy is offline   Reply With Quote
Old 05-04-2015, 03:45 PM   #2
That is your compressed air... Or at least it is in my 400bh
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 05-04-2015, 03:48 PM   #3
tmmar's Avatar
Paul,
Yes, it is a quick connect for an air line. You can use it to fill your tires or anything that needs air. You just need to have the engine running in order to keep the pressure in the tanks up. There is also a quick connect for propane in the passenger side compartment that is just ahead of the large door that is ahead of the rear tires. It is up and to the left.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-04-2015, 03:53 PM   #4
Thanks. I knew about the propane quick connect.
Old 05-04-2015, 06:29 PM   #5
Two things...... The connectors for the propane and the air chuck are NOT at all compatible, so remember that if you try to buy hose fittings for either.
Second..... IF you do get an air hose for filling tires, etc PLEASE have a really good grip on the hose when you release the chuck coupling. 125 lbs of pressure will blow that hose out of there like a shotgun.
If you're not holding on really tight, you could easily lose teeth, an eyeball or something. Trust me, it truly is like a cannon!!
Boowho??
boowho is offline   Reply With Quote
Old 05-04-2015, 06:48 PM   #6
Real good advice!
SkipnTerri is offline   Reply With Quote
Old 05-05-2015, 07:30 AM   #7
Thanks everybody.
Old 05-05-2015, 07:34 AM   #8
I-RV's Avatar
I moved the air horns out of the way, to provide space for hanging 50 ft of air hose next to the MH's air outlet.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 05-05-2015, 07:39 AM   #9
edgewant's Avatar
I've got one of those coiled hoses and I store it in the compartment where the generator slide release is located
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-05-2015, 08:42 AM   #10
iowasparrow's Avatar
Don't use it to fill your tires. The air that comes out of it is not compatible with the nitrogen you put in your tires. I think it's a different kind of nitrogen.
iowasparrow is offline   Reply With Quote
generator
