Old 10-13-2015, 10:19 PM   #11
baddmann's Avatar
Onan Cummins RV QD 8000 Oil & Filters:
Onan Generator 8HDKAK11296D
Oil: 3 quarts
Rotella T6 5W-40 (This is the oil I choose to use. Manual recommends something else)
Oil Filter:
Onan: 122-0833
Fram: PH3593A
Fram Ultra: XG3593A
WIX: 51064
Fuel Filter:
Onan: 149-2513
WIX: 33063
Air Filter:
Onan: 140-2897
WIX: 49697
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 10-14-2015, 05:09 AM   #12
Baddmann nice reference info.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-14-2015, 06:26 AM   #13
baddmann's Avatar
Thanks. I researched and compiled the info in a word document so I don't have to go looking every year when I need to do maintenance. I got some of the info here (thanks FR forum!) and the rest I found on the internet.
Keep in mind, the generator comes with a smaller oil filter. Its only for the 50hr break in period. When you do the first oil change the oil filter you use will be larger, but its also good for the next 150hrs.
Brian and Kelly
Old 10-14-2015, 06:36 AM   #14
Fulltime in our Berkshire
KennyGolub's Avatar
Thanks to all !!!
Great info. I'll store it somewhere so I don't lose it.
I can't say how much I love this forum, enough.
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 10-14-2015, 08:01 AM   #15
gasman94's Avatar
[QUOTE=baddmann;1009350] I researched and compiled the info in a word document so I don't have to go looking every year when I need to do maintenance.
Baddmann, you are way more sophisticated than I am. I just place a 2 inch piece of masking tape on the top of the generator with the date, oil type and amt., filter # and any other service that I performed at that time. I wonder if that kind of "record" will hold up at warranty time? (although I do save receipts)
Rich
gasman94 is online now   Reply With Quote
Old 10-14-2015, 01:09 PM   #16
JTN8's Avatar
Oil: 3 quarts
Oil Filter:
Onan: 122-0833
Fram: PH3593A
Fram Ultra: XG3593A
WIX: 51064
Fuel Filter:
Onan: 149-2513
WIX: 33063
Air Filter:
Onan: 140-2897
WIX: 49697
Ensure you look at your spec code on your generator. I have the QD8000 but mine takes a different fuel filter than mentioned above. I found this out this past weekend when I was in the infield of Charlotte and my generator was surging with a heavy load and then would stall. Went to the RV store and got the fuel filter mentioned above but when I went to replace it mine looked like the picture I posted below. Needless to say, there are different part numbers even though we have the same generators. Luckily they had mine also and I picked it up and replaced the filter with ease.
Jason
Name:	ImageUploadedByForest River Forums1444846094.491851.jpg
Old 10-14-2015, 02:20 PM   #17
gasman94's Avatar
Jason
Attachment 91527
Hey Jason, that is the filter that I have, also. What is the part# and is it a simple squeeze clamp removal, replace, prime and go? Also, how many hours did you have on your genny when you had the problem? I only have about 27 on mine and have always used fuel stabilizer when storing and also try to run it for an hour every 30 days or so.
Rich
Old 10-14-2015, 05:47 PM   #18
JTN8's Avatar
Rich
Rich,
Sorry I did not keep the box with the part number. The RV dealership I got it from said there is only two different ones for that generator. The one earlier mentioned and the one we have. Any RV place or cumins dealer should know it if you give them your serial number.
I had about 700 on mine and the filter was not the issue so I would definitely not worry at 27.
My issue ended up being that I just had warranty work on the generator and when they were done, they never clamped the electrical and fuel lines back up so they were getting kinked when I closed the generator. I figured this out after I changed the filter. So 700 hours and technically it would have still been fine.
Easy change, you need to cut the old clamps off or cut the hose and then use normal clamps when reinstalling new filter. Both ends of the hose is plenty long enough if you cut them at the clamp. That is what I did and the dealership service guy recommended.
They gave me the NAPA brand of fuel filter.
Jason
Old 10-15-2015, 06:26 AM   #19
KennyGolub's Avatar
I have the can shaped fuel filter also.
If anyone discovers the correct part number for it, please post it here.
Thanks,
Ken
Ken & Laurie
2016 Chevy Colorado
Old 10-15-2015, 07:31 AM   #20
JTN8's Avatar
Thanks,
Ken
Just called the dealer that gave me mine and I got the part numbers.
I used the NAPA gold - 3310
The Cummins fleet guard is -FF5190
Air filter for NAPA is 9697
Jason
generator
