Old 10-04-2012, 06:00 PM   #11
tmmar's Avatar
Mine is mounted under the panel where the slide switches, water heater switch, tank/propane/battery gauge is located. Never new it had the ability to auto start the generator. Will need to look into that.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-05-2012, 09:01 PM   #12
Future Berkshire Owner
Joker's Avatar
I don't know if you have a residential style refrigerator, but I heard the autostart feature is required for them. I suppose it is supposed to protect your fridge contents in case you drain the batteries. (anyone else ever wonder why 'fridge' has a 'd' in it, but the word 'refrigerator' has none?)
Joker is offline   Reply With Quote
Old 10-05-2012, 09:11 PM   #13
No
Old 10-05-2012, 09:19 PM   #14
Berkshire 390QS
NO3putt's Avatar
No residential fridge, asked FR for a build sheet on the HM, but not holding my breath. Have looked everywhere for the control panel, only place left is a small covered gray box up by the generator but I think it's just a connection point where the generator cables join the cables going to the rear. If we don't have a genset autostart, then the bigger question is why the generator started on it's own. Guess one way is to let the batteries run down and see what happens.
NO3putt is online now   Reply With Quote
Old 10-06-2012, 05:35 PM   #15
Joker's Avatar
Mine has a battery disconnect switch. Wouldn't throwing that switch have the same effect as running down your batteries if yours has some sort of autostart?
Old 10-06-2012, 05:41 PM   #16
Berkshire 390QS
NO3putt's Avatar
Great idea, however if I switch the battery disconnect, then the generator can not start since it has no battery. I have turned off the battery disconnect before and generator never started.
Skip
Old 10-06-2012, 10:14 PM   #17
Joker's Avatar
Oh, ok. I was thinking the generator started off the chassis batteries. I guess the run-down technique is your best bet.
