12-20-2015, 11:59 AM
Gerard tankless GSWH-1
ok all, couldn't find an answer. Using the hot water it is warm not hot. I havea 2013 RBQ. tried finding the mode switch with no luck. also is there a valve somewhere that the dealer might have turned last year when they winterized it?
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
12-20-2015, 01:17 PM
I think that you have a gen ll. This would have a rotary dial for control. Mine is found in the medicine cupboard near the shower in my 390fl. If it is a gen l, I think it is only a switch and I don't know where they located those.
Rich
12-20-2015, 04:36 PM
Best bet is to call Gerard in the morning. They are on the left coast so they open at 10 i believe. You might have a bad sensor. Assuming you have the dial set.
12-20-2015, 05:52 PM
i put a pressure regulator (50lbs) on the hose and the water seems to be hot to the wifes liking now.
12-20-2015, 05:54 PM
ive checked everywhere except probably where it is, and still can't find a dial or switch...
12-20-2015, 07:17 PM
Rich
I have a 2013 390RB and I believe I have a Gen 1 as well (at least that's the literature I have that came with the coach).
Glenn and Darcy
2018 Berkshire 39A
2016 Jeep Wrangler Unlimited/Blackbear (toad)
Pacific Northwest
12-20-2015, 07:19 PM
I think your mode switch is right above your slide switches. Should be "auto" and "low".
Glenn and Darcy
2018 Berkshire 39A
Pacific Northwest
12-20-2015, 08:21 PM
switch
no switch above slide panel
12-20-2015, 09:06 PM
Haven't seen any kind of switch in my 2012 either
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
12-21-2015, 08:20 AM
The switch on my 322RK is in the kitchen above the cabinet doors below the sink. It is labeled low and auto.
12-21-2015, 10:18 AM
Duh, it's right here
12-21-2015, 10:21 AM
umm...ok...
12-21-2015, 07:30 PM
I have a 2012 390Bh60 and fought with this exact issue until last summer.
The solution is as follows.
The unit is currently wired for low/auto. The auto switch is faulty .... as was the case with many of us.
Once you bye pass the auto switch the the unit with be high/low.
If you open up the outside access door to your water heater and look at the upper left of the back wall ... you will see the auto switch with a wire coming in and going out. If I remember correctly the switch is about the size of a quarter with two blade connectors.
If you remove both wire from the switch and connect them.together, you problem will be solved.
I also stopped using the small (low flow) barrel type pressure regulator and installed a high flow watt regulator that I purchased at Lowe's.
12-22-2015, 07:56 AM
Now to figure out how to make it work with the built-in pump!
Sent from my SM-G920V using Tapatalk
Jeff and Elaine
2011 Berkshire 390QS
2 Lab Dogs-Eros and Star
1 Cockatiel-Lucky
