Old 12-20-2015, 10:59 AM   #1
Scokat's Avatar
Gerard tankless GSWH-1
ok all, couldn't find an answer. Using the hot water it is warm not hot. I havea 2013 RBQ. tried finding the mode switch with no luck. also is there a valve somewhere that the dealer might have turned last year when they winterized it?
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
Old 12-20-2015, 12:17 PM   #2
gasman94's Avatar
I think that you have a gen ll. This would have a rotary dial for control. Mine is found in the medicine cupboard near the shower in my 390fl. If it is a gen l, I think it is only a switch and I don't know where they located those.
Rich
gasman94 is offline   Reply With Quote
Old 12-20-2015, 03:36 PM   #3
Best bet is to call Gerard in the morning. They are on the left coast so they open at 10 i believe. You might have a bad sensor. Assuming you have the dial set.
Old 12-20-2015, 04:52 PM   #4
Scokat's Avatar
i put a pressure regulator (50lbs) on the hose and the water seems to be hot to the wifes liking now.
Old 12-20-2015, 04:54 PM   #5
Scokat's Avatar
ive checked everywhere except probably where it is, and still can't find a dial or switch...
Old 12-20-2015, 06:17 PM   #6
Go Seahawks!
Subsailor's Avatar
Rich
I have a 2013 390RB and I believe I have a Gen 1 as well (at least that's the literature I have that came with the coach).
Glenn and Darcy
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 12-20-2015, 06:19 PM   #7
Go Seahawks!
Subsailor's Avatar
I think your mode switch is right above your slide switches. Should be "auto" and "low".
Glenn and Darcy
Pacific Northwest
Old 12-20-2015, 07:21 PM   #8
Scokat's Avatar
switch
no switch above slide panel
Old 12-20-2015, 08:06 PM   #9
jegstrup's Avatar
Haven't seen any kind of switch in my 2012 either
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 12-21-2015, 07:20 AM   #10
The switch on my 322RK is in the kitchen above the cabinet doors below the sink. It is labeled low and auto.
dmac1951 is offline   Reply With Quote
tank, tankless
