Old 11-09-2015, 09:38 PM   #131
7 Year Class A RV'er
One other thing. Check the sail switch on the exhaust port. Sometimes (at least on the Girard) that switch can get stuck and not swing right in the blower exhaust. If it doesn't sense air flow through the exhaust port, it will shut off the gas for safety.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 11-09-2015, 09:42 PM   #132
I'm fairly new in dealing with the Atwood. I haven't had time to mess with it. The sail switch on the Gerard drive me nuts. I even carried an extra one. I'm not summer how the sail switch works in the Atwood.
We really need more info to help zeelarry.
Old 11-10-2015, 06:41 AM   #133
15berkxl's Avatar
The only problem I have had other than switch turned off (like Phil mentioned) was the black tube that polks through the hole in the cover gets plugged with dirt (we believe from insects). Take tube off and clean it with tooth pick also carefully use pick to clean connection where that tube mounts to the diaphragm switch.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 11-10-2015, 08:10 AM   #134
nathantoensing's Avatar
Yea happens to us randomly as well. Take off the cover outside. On the top left there's a small red button. If you press it and it 'clicks' that's the reset switch. Seems to reset on us when windy, otherwise I have no idea why it trips!
--Nathan
2016 38a
--Nathan
2016 38a
nathantoensing is offline   Reply With Quote
Old 11-10-2015, 03:45 PM   #135
zeelarry's Avatar
--Nathan
2016 38a
Well, just got off the road, went to the forum and read all the feed back. As Nathan had said, push the reset button and BINGO!!!
Actually, I went to the top left of the tank, from the outside, and pushed the only thing that was RED [where the 2 wires met]. And that was it...
Now, it doesn't look anything like a button to me. To me, it looks like the end of a wire that was clipped off. Either way, it worked.
THANKS to EVERYONE with the input. I was use to the 10 gallons gas/electric water heater. Several new items on this coach & I now know that I do have a big learning curve ahead of me. The worse thing is that I've had previous Class As, with the latest one being a Diesel Pusher, 2009 Coachmen Cross Country.
AGAIN THANKS. . . still having a problem of thinking that thing looking like a clipped wire is a button...
Larry [US Army-Ret/Department of the Army Civilian-Ret/DAV];with Diane [Teacher-Ret]; 'Litabit' & 'QTπ' [Westies]; 2016 Berkshire XL 40RB/380 Turbo Diesel - 2015 Jeep Wrangler Sahara Life is GOOD Little Rock, Arkansas
zeelarry is offline   Reply With Quote
Old 11-10-2015, 04:32 PM   #136
Glad you got it working.
Old 11-10-2015, 05:01 PM   #137
tmmar's Avatar
X2!!
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 11-10-2015, 07:34 PM   #138
zeelarry's Avatar
Originally Posted by tmmar View Post
X2!!
Me. . . X3
Old 11-22-2015, 12:01 PM   #139
Gerard water heater in 2015 Berkshire XL
Wayne
I had no HW this morning so outside I went to check on why. Thanks to Wayne I saw that the heavy rain we had filled this tube with water and didn't allow the heater to work. I took it off and blew it out. Back up and running. It's a weird design but at least an easy fix.
I do believe just about every problem and fix is available on this page. Thanks guys for all the info. I wouldn't want to try to figure this out by myself.
Old 01-02-2016, 01:44 PM   #140
We had the same issue; it was the sail switch. The sail switch is that small arrow shaped fin in the exhaust opening. If it is stuck the burners will not ignite. Just remove the sail switch, lube and replace it. It's a simple fix.
sFRving is offline   Reply With Quote
berkshire, heater, water, water heater
