Old 07-01-2015, 11:22 AM   #11
7 Year Class A RV'er
OK - here's how to use the tankless heater.
1. Somewhere in the RV (ours is in the upper cabinet in the front bathroom), there's a small knob. You turn this knob to determine how much temperature rise you want in the water between the incoming temperature from the source and the water temperature at the shower, etc. In summer months, this knob is set to low as the incoming water us warmer. In colder weather, adjust the temperature rise higher. Remember, this is the Delta T, or increase in temperature, if the water, not the actual water temperature.
2. When showering, etc., DO NOT turn on the cold water like you normally would. This will cause the flow rate (GPM) to the Girard to fall and can cause it to shut off. Just turn on the hot water only FULL FORCE.
3. If the water is too hot, adjust the knob I mentioned in Step 1. If you want the water hotter, just reduce the flow rate by turning down the hot water faucet. As the flow rate drops, the water will move through the heater slower and thus has longer to heat.
4. The flow sensor in the heater only allows the burner to light when hot water is flowing. When the hot water is turned off, the burner should immediately shut down. To be safe, there are two temperature sensors in the ECO (emergency cut off) switch that will shut down the burner if the water gets too hot. If that happens, the lower ECO switch is white with a small reset button you can push.
Hope that explains what I meant by the procedure. Just reply if other questions. Good luck!
2015 Legacy SR340 360RB
Old 07-01-2015, 11:26 AM   #12
Great explanation of how the WH works. It's not rocket science but it's also not your home system either. This issue comes up more often than anything else. It does explain how to in the literature everyone got but who reads right?
Old 07-01-2015, 01:05 PM   #13
Campin Cajun's Avatar
I must be the oddball out, mine works perfectly. I also use both hot and cold water in the shower to adjust temps. I have the temp dial in my bathroom cabinet just like stated above. The only thing I do differently is use some cold water mixed in with the hot.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-01-2015, 01:53 PM   #14
Camping you can get away with that if you have great water pressure. If you have poor or average the limit switch will cut out as the water gets to hot in the water heater itself.
Old 07-01-2015, 03:53 PM   #15
I'm really glad to hear it's working for you, Campin Cajun - gives me some hope that mine will perform properly when they get it fixed. Right now, I had to leave it there today so they could get the parts and try to make sure everything gets fixed. The tech was telling me he's had much better luck if he replaces both the ECO (emergency cut off) switch and the flow switch at the same time, so I think that's what he's planning. They did say they've had at least one customer that they had to replace the Girard with the Atwood model they are using in the 2016's. The Atwood fits in the same opening in the RV, but it has a larger cover, so you have to send the cover over to the body shop to be painted. Hope I don't get to that stage.
Old 07-01-2015, 03:59 PM   #16
Our issue is that the entire unit does not fire up. We can hear the flow sensor kick on but the gas never turns on. OR, the blower turns on but the gas never a comes on. I've turned the water off as in the instructions and waited and turned it back on but it still doesn't fire up. Sometimes the only way to get it started is to bang on the black control box and then start over. This works SOMETIMES. Very frustrating.
williamthiess is offline   Reply With Quote
Old 07-01-2015, 04:03 PM   #17
There's another post somewhere on here by someone who had that same problem. It turned out to be the sail switch was stuck. Look in the end of the exhaust screen and you'll see a small triangle of metal hooked on to an arm that attaches to a switch mounted on the side of the exhaust tube. Make sure it is moving back and forth when the blower starts. If it doesn't get blown outward by the exhaust fan, it won't kick the relay that allows gas to flow as it thinks the blower is not exhausting. You can probably move it with your fingers to see if it's the problem.
Old 07-01-2015, 05:18 PM   #18
tmmar's Avatar
conceptumator,
You are correct. I had forgotten about the sail switch. I should have remembered it and posted about it a while ago. Might have saved someone some agita!!
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-01-2015, 10:05 PM   #19
Girade hot water heater
We set our temperature at the lowest setting and turn our shower on with just the hot water on. The lowest temperature setting is scalding hot! We bought an oxigenics shower head and the water is still scalding. We turn on the cold water to make the water tolerable, but the we get hot and cold surges. Is there anyway the temperature on the dial could be off? Could it somehow be readjusted?
PFurlow is offline   Reply With Quote
Old 07-01-2015, 10:26 PM   #20
You might want to talk to the Hirard folks. I didn't get any details, but the service tech I spoke with this morning at the dealership mentioned that there was a new revision of the temp control switch and he was going to swap mine out. Could have misunderstood, but that's what I got out of it. From what I understand, the knob controls the size of the flame on the heater. You should be able to see the difference in the flame at either end of the setting range. Guess it's possible something could be working backwards.
berkshire, heater, water, water heater
