Old 11-07-2014, 01:15 PM   #11
Mmnsc's Avatar
Did you check the outlet in the basement closest to the entry door? There should be one there and also the outlet in the furthest rear basement on the drivers side. The is an outlet in there for the engine heater plug. Those are the only 2 others that I know of.
Mmnsc is offline   Reply With Quote
Old 11-07-2014, 01:30 PM   #12
Just A Member
marc7's Avatar
Had a similar issue about a month ago...Turned out one of the legs on the 50AMP service at the pedestal was not making good contact....Once that was addressed I was back in service...
Cheers!
2008 Toyota Tundra Limited
2013 Rockwood 8325SS Diamond Package
Days Camped 2012: 80
Days Camped 2013: 101
Days Camped 2014: 115
marc7 is offline   Reply With Quote
Old 02-21-2015, 09:50 PM   #13
jmgllt's Avatar
This was the reply, where is this I'm having the same problem!
You should see your TV also does not work until you reset the inverter breaker.
jmgllt is offline   Reply With Quote
