Old 06-27-2016, 07:51 AM   #21
15berkxl's Avatar
Originally Posted by dhornback View Post
Making some progress. The black tube had "stuff" in it. Took that off and cleaned it. Did not have small nail so that was the extent of cleaning. Does the black tube connect to the pressure switch. Do not have may manual. To jump it do I take off the wires attached to the round pressure switch and touch them together ?
It is an Atwood unit.
Maybe I am almost there but touching the wires together causes me to double check.
Thanks again.
Run into Walmart and get some pipe cleaners they work great for cleaning that tube.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 06-27-2016, 08:33 AM   #22
Girard is having a gas valve issue on some of the 3rd Gen units. Mine is one of them. Needs replacing which they will cover. If you are a DIY guy, they will send it to you. If not, they have warranty provisions to have dealer do it. Call them and they will walk you thru the temp fix to get it to work.
Jon A is offline   Reply With Quote
Old 06-27-2016, 01:08 PM   #23
EJM4's Avatar
Anyone have a good phone number for Girard? I just get the leave a message response.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 06-27-2016, 03:20 PM   #24
EJM4's Avatar
Spoke to Girard this afternoon. They told me that I have a flow valve problem. The switch that I jumped was the temp switch for cold weather operation.
Any way tried tapping on the flow valve and no go. New valve ordered and bring shipped. In the mean time jumping the temp switch gets us hot water.
Earl
Old 06-27-2016, 03:51 PM   #25
Good to know.
Old 06-30-2016, 06:52 PM   #26
KennyGolub's Avatar
Mine crapped out on us tonight. I tapped Something and it finally kicked on again. fan and water was running but the heater wasn't igniting. I really dislike Gerard stuff.
Ken & Laurie
2015 Tiffin Allegro Bus 45LP
2018 Jeep Wrangler Unlimited
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 06-30-2016, 06:58 PM   #27
tmmar's Avatar
I found that when it rains and if there is water in the water heater compartment, that the heater will only cycle on for a few seconds. Once I dry the compartment out, everything returns to normal. Just my experience with the Girard gen 2.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-30-2016, 07:57 PM   #28
EJM4's Avatar
Well... I installed the new flow swith and the fan and igniter come on, but it won't fire.
I'm tired of messing with it. We are headed towards home tomorrow and will drop off at the repair shop.
This water heater version 1 and version 2 are the two biggest complaints I have with our Berkshire.
I would love and pay for a traditional hot water heater.
Earl
Old 07-01-2016, 05:16 PM   #29
Tom I think I also get water into the water heater area, although haven't noticed anytime that it hasn't worked. Do you also get water in the compartment below the water heater ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 07-01-2016, 07:34 PM   #30
tmmar's Avatar
Never looked into the compartment below the water heater. It has been raining here in Orlando much of the afternoon so I will check tonight.
Tom and Margaret
