Old 06-25-2016, 08:58 PM   #1
EJM4's Avatar
Girard Gen 2 Won't fire
Girard Gen 2 will not fire. You can her the water running thru the water heater, but the fan nor the flame will ignite. Suggestions?
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 06-25-2016, 09:04 PM   #2
Go outside open cover turn off press reset little black botton top left hand behind panel little round botton. Turn back on should light when water flows now
Lumpy is offline   Reply With Quote
Old 06-25-2016, 09:23 PM   #3
Is the fan behind the sail switch running?
Old 06-25-2016, 09:28 PM   #4
EJM4's Avatar
No, the fan will not turn on.
Earl
Old 06-25-2016, 09:30 PM   #5
Play with the sail switch. The paddle sometimes gets hung up. Just gently move it around.
You can also jump the switch for diagnostics only. Do not run the heater with this switch jumped.
Old 06-25-2016, 10:12 PM   #6
Mmnsc's Avatar
My fan switch was not allowing the burner to light. It was sticking so I put 1 drop of T-9 on the pivot point of the switch and have not had a problem since. The fan switch is a micro switch that has a very light spring built in. If the switch does not move freely the burner will never light. Also if the red light is on, turn off the rocker switch to restart the program. If the red light is on the unit will not ignite.
Mmnsc is online now   Reply With Quote
Old 06-25-2016, 10:25 PM   #7
Mmnsc's Avatar
I meant "Sail" switch when I referred to it as fan switch. The Sail switch controls the fan. Sorry for any confusion.
Old 06-26-2016, 06:58 AM   #8
EJM4's Avatar
The switch and little flapper move freely. Now when you turn the hot water heater on, you can almost hear a clunking noise but nothing happens.
Earl
Old 06-26-2016, 08:42 AM   #9
Get a short piece of wire and strip both ends. Turn the hot water on in the Moho and start jumping switches until the heater fires. You will find which switch is bad. A call to Gerard Monday and they will have the new switch on the way.
Old 06-26-2016, 09:27 AM   #10
EJM4's Avatar
Thanks for the tip. Could I be missing a fuse or breaker somewhere?
Also my unit has no reset button.
Earl
