Old 11-29-2018, 10:22 PM   #1
erniet's Avatar
Girard GSWH-1M and winter traveling
I'm preparing to leave WI soon after Christmas. For the last several years I've left at this time period with a Winnebago filled with water and had no problems, even at -10°F. But now I've got a Berkshire??? I think I'll be able to supply enough heat to my water tank area and also water manifold to keep them from freezing.
My question is what about the water line to the Girard? The manual says the Girard will protect itself.
Does anyone have experience with this Girard traveling with water at cold temps, close to 0°F?
2014 Berkshire 400QL; sometimes towing 2007 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
erniet is offline   Reply With Quote
Old 11-30-2018, 12:46 AM   #2
NMWildcat's Avatar
We have the GSWH-1 and it is equipped with the winter use device (WUD). Here is the manual: https://www.manualslib.com/manual/12...ducts-Wud.html
You just have to ensure the tankless is turned on, the pump is on, propane is on, and you have fresh water in your tank for it to work.
Some WUDs are plumbed to return water to your fresh tank, others to a gray tank.
So far ours has worked fine for the last 6 years when the temps approach freezing.
Scott and Liz - Southern NM
Old 02-17-2019, 10:41 PM   #3
Terrilegacy's Avatar
Has any had to replace their GSWH-1? I cant seem to find one. The newer model GSWH-2 will not allow you to use you old door. This is important if it is painted to match you coach. I can't image what that would cost on top of the new heater.
Terrilegacy is offline   Reply With Quote
Old 02-18-2019, 01:17 AM   #4
Dragonship Captain
Oscarvan's Avatar
Can't help you with your Girard, but I know people have successfully painted their own door. Won't be perfect, but from 10 feet you won't be able to tell.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 02-18-2019, 06:00 AM   #5
I replaced mine with a Truma (so happy with it), my old door was 1/2 black- new door I ordered it in black- was going to paint but does not look to bad. No worse than windows.
2012 390BH
dave-g is offline   Reply With Quote
Old 02-18-2019, 04:32 PM   #6
edgewant's Avatar
My GSWH-1M doesn’t have the bypass solenoid but does have the WUD. It just turns the heater burner on when the water temp in the burner manifold reaches 38 deg F. No water is circulated. It protects the water heater but not the rest of the plumbing.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
travel, winter
